Question about Lexmark T632 Laser Printer
Lexmark T632 says "Load MP Feeder Letter
I tried powering off and restarting did not help.
  • Anonymous Jan 29, 2009
    load me feeder
  • 66 Answers
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Posted on Dec 19, 2008
Lexmark T632 says Load MP feeder letter. The problem is with the paper size selector slider on the paper tray. Simply slide or glide the paper size selector to LTR. You'll see several markings on the left hand side of the paper tray to select from such as B5, EXEC, LTR, A4. Slide the selector to the LTR position. Matter of fact, I selected LTR for all three paper trays and have had no problems since.
Posted on May 20, 2011
Factory reset should fix it unless the paper size ciruit board and levers have been physically damaged (back left on the printer in paper tray slot)
Posted on Jun 10, 2010
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
This is telling you to load Letter sized paper into the multipurpose feeder. Take the paper that is in the tray out and place in the correct Letter sized (8.5"x11") paper into the tray
Mar 08, 2011 | Lexmark Optra M410 Laser Printer
My lexmark t430 says load mp feeder letter. what does this mean?
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray).
If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
Feb 23, 2011 | Lexmark T430 Laser Printer
Load MP loader
Here's an article in the Lexmark website on Message: "Load MP Feeder". Just click on this link: http://bit.ly/9KTSp2. Follow the instructions carefully. Hope this helps.
Jun 14, 2010 | Lexmark T632 Laser Printer
Messagr: load mp feeder letter
try to check on this link:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_T632&page=product#3
Nov 03, 2009 | Lexmark T632 Laser Printer
Hi, my name is Fernson I have a Lexmark t630 anytime i try to print something it says "load mp feeder letter "
Load "MP" means to load media into the Multi Purpose feeder , which is in the front of the printer.
This can be caused by several things, all of which are easy to fix.
First, open the printer driver and verify the correct selection of media draw.
Next, ujse the printer's paper menu to set the proper tray.
Lastly, make sure that the print file going to the printer is not asking for the MP Feeder.
May 07, 2009 | Lexmark T630 Laser Printer
How do you take the printer off of manual feed?
Are trying to print to the MP feeder? If not, then you need to check whether or not is the selected paper source. Step 1: Go to the Printer's paper menu and scroll down until you see the Tray Select. Go into that menu and verify that the correct selection has been made. Step 2: Go to the "Printers and Faxes" Windows menu and then select your printer and verify the paper size and tray settings. Step 3: If you are using an application such as Word, go into page setup and verify that you have the correct setting. Last step, go into the driver, select "Print to File" and print the file. When prompted to name the file, name it mpfdr. Windows will append a .prn to the file name. Send the file to: janddgasrepair@verizon.net. I'll read it and see if I can fix it for you. Don
Apr 02, 2009 | Lexmark T632 Laser Printer
Will not print
Try to power down the printer (including unplugging it from the wall) then take out the paper trays. From there, reseat the tray guides (so pull them all the way in, then all the way out). From there replace the paper in the tray, and then re-align the guides to the paper. Plug it in, and then try a test print.
Apr 03, 2008 | Lexmark T632 Laser Printer
Lexmark T632 Laser Printer Logo
4,603 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
