FixYa.com
Tags:
Dell OptiPlex GX260 PC Desktop
Hard Drive Error (by 4 users)
posted by kitty2380 on Sep 27, 2006
I am trying to reinstall windows 2000 pro on my computer but ever time I start it up i get a hard drive error...I have tried 4 different drives and get the same error, if i hit the F1 key to continue it will go into windows, but if I restart the computer or shut it down i still get the error.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by narrowman198, posted on Jul 24, 2008
Pls guide me format and reinstall OS in a IBM thinkcentre desktop
There is no boot device preference in BIOS also
Comment by Guest, posted on Jun 28, 2008
I am getting an error on Acer S290 that is an error screen showing while it booting.Now i can't install or repair the system .It is showing that the any hardware problem like memory or graphics card .It is also recommend to run diagnostic utility ,but i don't have that CD and i don't know what to do .
Comment by Guest, posted on May 16, 2008
MON PC A DES PROBLEMES DE SOM ET IMAGES QUE POURAIS-JE FAIRE ? POUR INSTALER LES DRIVES DE SON ET IMAGES
Solution #1
posted on Jul 19, 2008
Not Rated (0)
linkin
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
reset your bios by removing the battery, then putting it back again. Or keep holding the Page Up key when rebooting your computer.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 22, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Rating: 76%, 113 votes
I was having the same problem a couple days ago. I took the hard drive out and put it into my other computer as a slave and then formatted the drive with windows then put it back into  the first computer then it wanted to work fine. Be sure and set first boot as the cd rom, second boot as ide and third boot as floppy if you are using any.
Solution #3
posted on Sep 07, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I believe the problem is that windows does not have the correct HD controller driver by default. Therefore, it never load the driver for the controller and the HD is not seen.
usually see this on scsi controllers, but i have seen it on a few newer SATA HD controllers.
Solution #4
posted on Sep 06, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Windows 2000 is bad about that. Reformat your drive and try again.
Solution #5
posted on Aug 07, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
you need to use a format disk and clean and reformat your disk first before you try and load the operating system. Then you may need to press del or f2 after booting to go into the bios and set the cd rom to first boot, you may have to change it several times as you format with a floppy startup disk first
Solution #6
posted on May 23, 2007
Not Rated (0)
xavier55
Rating: 0%, 0 votes
i would suggest to try a BIOS reset without a harddrive pluged in, you schould find 2jumpers on the motherboard just plug the green plastic down and plug it on the other one back (on the one where no plastic is) make this withouth power added to the system,then make the setting with the jumper back and plug the hdd in,afther a start will the bios go to a routine to scan the ide ports.
Solution #7
posted on Sep 27, 2006
Not Rated (0)
dugiehowsa
Rank:Wiz Wiz
Rating: 78%, 733 votes
This sounds like an issue with the BIOS rather than your hard drive if you are able to boot into Windows. Or do you mean that the PC boots to the windows install?
What is the exact error and at what point in the boot process are you seeing it?
The BIOS handles the the initial startup of your computer, before Windows is even accessed on the hard drive.
If you can boot into windows, then try downloading the latest BIOS from Dell support and upgrade your bios.
If you cannot boot into windows, and the PC is just going to the Install CD, then there may be a problem with the connection to the hard drive. If you have tried different hard drives in the same PC, then try swapping out the cable that connects the hard drive to the motherboard. If different cables do not solve the problem, then the problem may lie with the connector on the motherboard. If thats the case, then the entire motherboard will need to be replaced.
Also try downloading the following CD to run diagnostics on your hard drive. This should provide further information as to what is wrong with your system:
http://www.ultimatebootcd.com/
This Problem Also Relates To: HP Pavilion a800n (PP163AA) PC Desktop HP Compaq d530 SFF PC Desktop HP HP PAVILION A6230N DESKTOP PC HP Pavilion a1010n (PS563AA) PC Desktop HP Pavilion a1200y (EK457AV) PC Desktop HP Compaq d220M (829160054797) PC Desktop HP Pavilion a810n (PP164AA) PC Desktop
Can you Help with these PC Desktops problems?
PC Desktops
hooked tv up to pc
hooked tv up to pc and it said... Answer This...
PC Desktops
email address
I have had other profiles with... Answer This...
PC Desktops
my acer aspire 5315 dvd
my acer aspire 5315 dvd drive... Answer This...
PC Desktops
when i open my loader
when i open my loader it says... Answer This...
Odd Dates reported
Hi, Using an Optiplex GX 260,... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
