Question about Roper Kitchen Ranges
Can't find a replacement valve for my Kenmore (by Roper) stove urner. GE mfg'd it, part 332002.
I was actually able to repair the original valve. Upon very close scrutiny I could see it could be disassembled.
Posted on Apr 01, 2009
Can I replace a kenmore stove burner with a GE burner
It depends on the Kenmore Model. Kenmore is the brand name for models sold by Sears, but they are not all manufacturered by the same company. They are made by Frigidaire, GE, Whirlpool, Amana, Samsung, LG... just to name a few. If you can post a model number of your Kenmore, I can give you the options for which elements will work for your machine.
Jul 11, 2013 | Hotpoint WB17X5113 Stove Surface Burner...
What is the difference between the Kenmore 953 fifty and seventy
SEARS/KENMORE
Range/Stove/Oven Manufacturers
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page. The first 3 digits of the model number determine who built it. Roper Whirlpool Caloric Kelvinator Gibson D & M 103
647
835
911
155 106
110
562
665
198 174
960 417
662
628 253 587 GE Speed Queen Maytag Litton Toshiba Fedders 363
362 651 925 747 562 484 Amana WCI Tappan Jenn Air 596 790 791 629
Apr 09, 2010 | Kitchen Ranges
What does E1 F2 mean? It just appeared and the oven and stove have been working fine
SEARS/KENMORE
647
835
911
155 106
110
562
665
198 174
960 417
662
362 651 925 747 562 484 Amana WCI Tappan Jenn Air 596 790 791 629 i dont see 950 are you sure not 960?
if 960 then temp of oven is too hot and sensor needs attention
Feb 19, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven heating element works but gas wil not ignight
the oven ignitor has to consume 3.2 to 3.6 amps in order for the oven valve to open. The valve is a bi-metal valve; which means the proper amount of current must be drawn through the valve to warp the bi-metal and allow gas flow. Oven ignitors will glow bright but only pull around 2.8 amps, not enough to open the valve. In most cases this is the scenario. The only way to determine which is bad(ignitor or valve) is to check the amp draw of the ignitor using a clamp on meter. If the ignitor is flat in appearance it must pull 3.2 to 3.6 amps, if the ignitor is round it must pull 2.5 amps. Being a kenmore stove it could be built by frigidaire or many others for that matter,the model # indicates this, so be sure to check the amp draw if possible.I have seen many Frigidaire oven valves bad.However, 9 times out of 10 the ignitor is bad. If your model begins with 790. its a frigidaire, 362. its a roper/ge, 665. its a whirlpool built, 911. its a roper, etc. hope this helps...
Nov 19, 2008 | Kenmore Humidifiers
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Burner goes out on simmer
look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Mar 07, 2008 | Roper FGP325K Gas Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
