Question about Vacuums
I have a kirby legend 11, the long handle is loose, how do I tighten it please?
    Problem Solver:
  • 7 Answers
If it is not staying up the handle falls down then is caused by the handle spring assembly. Replace the assembly and it should do just fine. There about 7 different components inside the shell, it's usually the spring but after so many years the bushing and shaft could be bad as well. Recommend to change the whole assembly and it does require a specialty tool to tension the spring assembly.
Posted on Nov 28, 2008
How do I tighten a handle on an upright Kirby vacuum?
Your question isn't specific enough. The upper handle grip has a bolt through the upper cord wrap that can be tightened. The lower handle has 2 bolts, but they rarely get loose. If you're concerned with the way the handle wobbles side to side at the base, that's normal. If you want a better diagnosis, take it to your local vac shop to have it looked at.
Feb 19, 2015 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Kirby Legend 2 Vacuume cleaner
call Francois Gordon 27 11 476 1235
Rocky
Jan 03, 2009 | Bosch Turbo Jet Bagged Upright Vacuum
Kirby Legend II
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11558&thid=818960
Kirby Legend II
Posted by smokey 1 on July 22, 2008
Hello, Help please, Using my vacuum, turned it off briefly, then went to turn it back on and it would not .I checked plugs which were both fine. Motor is strong, impeller is fine. The light comes on near the button to turn it on however it's not doing anything. Switch maybe? Just a guess. Thanks for your help! Alice
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It can be only one of 2 things, either it could be the safety switch or the foot switch and they would have to be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 22, 2008 | Kirby G4 Bagged Upright Vacuum
Hi I am looking for some where to get my kirby legend 11 vacuum cleaner serviced and probably a new brush head for it thanks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=722285
Generic problem for all Vacuums
Hi I am looking for
Posted by libbit1 on Jun 30, 2008
Hi, I am looking for some where to get my Kirby Legend 11 vacuum cleaner serviced and probably a new brush head for it thanks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In most cities there are factory authorizes Kirby Vacuum dealers that also do service in most of the big cities other wise there are your local vacuum cleaner dealers in your area that also do service on the Kirby vacuums. When referring to the brush head are you asking for the bell housing or the brushroll. The brushrolls are very available @ either dealer but the bell housing that the brushroll fits into you probably will need to get that from the factory or the local vac dealers may have a good used one for less money or ½ the cost of a new one. Just a suggestion for you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Kirby Legend 2 Vaccum cleaner
Did you ever find a use and care book for this vacuum.  I have one I could scan for you.
Jun 27, 2008 | Kirby Heritage II Vacuum
Legend II Kirby footswitch
I have a Legend II footswitch foolishly did not record the position of the wiring I have 2 reds for the light and a positive and negative could you tell me which wire goes in what hole please
I do not have schematics of the wring diagram in order to help you on this question but to be accurate you will need to contact a serv tech tat would be in the yellow pages , or call the Kirby factory service or some examples listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 ask for the service dept
Apr 18, 2008 | Vacuums
Legend 11 Kirby, sometimes will not turn on
Could have a problem with the motor, may need carbon brushes, or other motor related parts. If the light turns on and off with the switch, then the switch is probably ok. There is a speed switch inside the motor casing that could be bad.
Feb 21, 2008 | Vacuums
Bad fan
Take off the bag and handle, remove casing, then you can remove the front casing to get to the fan. Turn the belt spindle to the right to unscrew it, then pull off fan and replace it with a new one. You may have to lock the armature to be able to unscrew the spindle.
Oct 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
180 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
