In my Roxio Easy Creator 10, I put together a picture slideshow with audio. At the completion of burning a disk I received an error message: 80045020 Error while recording Slideshow. What went wrong?
    Master:
  • 763 Answers
Im not so familiar with roxio but i suggest that you use Ulead Producer or any Ulead softwares and Nero for burning. it so easy to use and user friendly too. hope that helps
CHARCOIS
Posted on Nov 03, 2008
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Purchased roxio creator 2010 in store and roxio 6 & 5 on line
Uninstall the software, and try to get a refund.
Then, access http://www.MajorGeeks.com
and download the _free_ "Ashampoo Burning Version 6" software. It's great software for burning both data and audio CDs and DVDs, and it is _free_ to use.
Apr 07, 2010 | Roxio Easy Media Creator 10 Suite
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
Error when attempting to write disk
Sometimes the driver that is used to burn CD's gets corrupted, you should try removing and re-installing roxio. The only other possibility is a bad CD burner drive, but these are dirt cheap to replace these days, you should easily be able to find one under 40$.
Jan 20, 2009 | Roxio Easy CD & DVD Creator 6...
Editing an EXISTING slideshow
For creating a new slideshow in videowave
Go to video wave, once it loads go to tools, select "new slideshow"
For opening a already created one
Sadly it is not possible under emc 10, you must find the file in windows, sorry
Try using windows search
Dec 12, 2008 | Roxio Easy Media Creator 10 Suite
Having installed Roxio Creator 10, I get a recurring message: "RoxMMTrayApp Module has encountered a problem and needs to close." Etc. It occurs even when I am not editing with that software. ...
ROXIO Multi Media Tray Application Module Has Encountered a problem and needs to close.
This Means ROXIO Creator 10 Try Application Encountered an error.
And since it happens while burning a disc
You should
1. Uninstall ROXIO Creator 10 , and reinstall it to make sure nothing is corupted.
2. If you still get the same problem it's time to check your intire system for errors.
This can mean you will need to take trouble shooting steps.
1. Use another burning program to see if you can burn without errors.
2. if you can burn fine with another burning program like NERO then chances are
you have an incompatability with ROXIO Creator 10 and should consult the documentation
to see if your drive is actually supported by it.
Do these things weed hopper and all will be well with you.
Az.
Sep 16, 2008 | Computers & Internet
I HAVE ROXIO MEDIA CREATOR 9 AND GET TO THE VERY END OF TRYING TO BURN A SLIDESHOW OF 750 SLIDE VS AND 7 AUDIO TRACKS AND AT THE VERY LAST MINUTE THE BURNING FAILS CODE 800700E ERROR WHILE ENCODING MENU....
You haven't mention which OS you are working with. I guess it is Windowsxp. Download nero and install it. It might help you to burn your files.I think that Roxio media creator is incompatible with your current OS.
Jun 17, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
