Question about Sony KP-53V45 53" Rear Projection Television
Good picture in the middle but picture gets worse going to top or bottom.
The picture in the middle of the screen is decent but the more you go to the top or bottom, the more you get the 3-D effect. My red seems to be the one out of wack. It bows in at the top and bottom.
  • ITExtra Jan 11, 2008
    My picture is distorted as well, but it seem the base green gun is what is out. I replaced STK392-110 with higher heat handling linear Sanyo "genuine"? STK 392-150's....SAME EXACT problem. Do I need to go into the service mode of the tv to recalibrate convergence??? If so, what are those convergence codes, and I WILL write down all values before resetting.
    President:
  • 3,130 Answers
The convergence IC's need to be replaced. they are the black standup IC's standing up and mounted on a metal heatsink. They are soldered into place and this set is a solid state set and have no user replaceable parts unless you have the training to solder and trouble shoot electronics. You should call a pro in to assist you with this repair.
Posted on Sep 27, 2006
Phone wont turn on
Replace new battery for your Iphone 4S, if problem still manifest.Try to replace new LCD Screen. :0
Sep 15, 2017 | Cell Phones
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Horrible picture on top & bottom of screen
I wouldnt reccommend that you try to fix it as it is a lot easier to make it worse that better. Basically your color guns have gotten un focused and will need to be adjusted. Call a tv tech and they can usually fix it for a decent price.
Oct 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Open Questions:
Televison & Video Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
