I recently opened up the tower case on my Gateway 500GR PC desktop to clean up the dust off. I also did take outthe fans and dusted them then put them back. However, the CPU fan sounds much louder now, like its spinning too fast than usual or something like tha. What could I have done wrong.. I checked it again and looks like I put it back correctly.
3 Other Users Have The Same Problem
Comment by applsauce7, posted on Apr 09, 2008
I have the same exact problem. I've never had a problem with my computer's fans being loud until I recently removed them to clean the dust out. Ever since I reattached them they have been EXTREMELY loud. But only occasionally. It only happens when I'm doing something processor intensive.
Comment by MBA Runner, posted on Feb 23, 2008
Fan runs constantly. Runs very loud.
Comment by mickyboy73, posted on Jan 04, 2008
I have the exact same problem. Mine is a Packard Bell PC. Normally when the PC is first started the fan runs at full speed for a few seconds and then slows to a normal speed and is very quiet. Since I tool the fan out and cleaned off the dust it is running at full speed all the while which is fairly noisy too. The noise is due to the speed of the fan. Could I have damaged the fan while cleaning it and putting it back in? Would a new fan solve this problem?
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Try setting the PC on its side. Does the noise level change?
Fans are a part of a PC that are almost always in constant motion, and thus are subject to faster degradation than other PC components. You should be able to easily replace the fan with a new one to eliminate the noise.
Also, you probably didn't place it in right or tight enough and so it vibrates against something.
Don't worry, but make sure that if you notice that it gets very quiet all of a sudden your fan may have failed and u should save all work and shut down immediately. Not very likely.
But fans are usually easy to replace; you could buy fans for 15$ and all you have to do is place them on the case and plug them in. There are instructions all over the internet.
Comment by Raging Aura, posted on Jan 06, 2008
Well hopefully you won't have any more fan trouble for a long time after doing all of that.
Check the fan power cable is correctly fixed
check the wires are touching the surface of the cpu fan
if the problems continues replace the fan and fix it correctly.
Let me know if your problem is solved and rate me as FIXYA!
I am monitoring the fan speed and CPU temp and all is fine ;-)
I could have replaced the heatsink and fan I guess but I wanted to know what was causing the problem.
New fan and some thermal paste and it's all good again.
Thanks to all for your help and I hope this may help others too.
If the fan was a thermal sensing fan then the sensor might have got bent. If both wires on the thermal sensor are touching, It will run at full speed. This will make it quite a bit louder.
Post a New problem for Gateway 500GR PC Desktop
Email this problem
