Question about Fujitsu Plasmavision 42" TV
Fujitsu p42vh a20as
I want to purchase a power module tnpa 2599 ab el3121b [el31z1b ?]
Dead. LED changes from green (around 8 sec) to red (1 sec), not flashing.
You need to check the connection stripe inside the monitor.
Aug 26, 2014 | Televison & Video
Why won't abs light go off error code says pump
When a pump code comes on for the abs it is usually associated with the module connected to the pump. Most of the time either the relay controlling power to the pump loses it's continuity on the board or the connector builds corrosion and resistance in the terminals. Most of the time depending on the make and model an the exact code it can be remedied by purchasing a new or used abs module/ pump, repairing the old module/ pump, or just replacing with a new module/ abs pump(most expensive option). It is very common for abs relay/ pump codes to appear and end up relating to the power or ground circuit going to open( breaking continuity it frying a connection form resistance)
Jun 05, 2014 | Chrysler Voyager Cars & Trucks
Brake pedal loosing pressure
Honda had two brake reservoirs one on the normal brake master cylinder the other on the ABS module. If abs fuse has no power the module has no power. that power comes from the main fuses in underhood fuse box. the abs system is supplement system to normal braking system loss of brake pedal is a air problem or drum brake adjustment problem or a loose wheel bearing pushing the caliper piston back into caliper requiring more fluid to get brake to work causing a low pedal.
Nov 12, 2013 | 1995 Honda Accord
Abs light on a 06 expedition
Having the vehicle checked for DTC'S - diagnostic trouble code's would be a good first step . ABS light on codes are stored . Suggest you take your vehicle to a qualified repair shop that has the knowledge an testing equipment to diagnose the problem properly .
Anti-Lock Brake System (ABS)
The 4-wheel, 4-channel anti-lock brake system (ABS) consists of the following components:
  • ABS module
  • Front wheel speed sensor
  • Front wheel speed sensor ring (integral to the front wheel bearing)
  • Hydraulic control unit (HCU)
  • Rear wheel speed sensor
  • Rear wheel speed sensor ring (integral to the rear halfshaft)
  • Yellow ABS warning indicator
  • As you can see here , it can set numerous
  • DTC'S Why guess an replace parts that won't fix the problem .
  • Anti-Lock Brake System (ABS) Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Faulted ABS Module NOTE: If other DTCs are present, REPAIR them before installing a new component.
    CLEAR the DTCs. RETRIEVE the DTCs. If DTC B1342 is retrieved, INSTALL a new module. REFER to Anti-Lock Brake System (ABS) Module in this section. REPEAT the self-test. B1483 Brake Pedal Input Circuit Failure ABS Module Go To Pinpoint Test B . B1676 Battery Pack Voltage Out of Range ABS Module Go To Pinpoint Test C . B2477 Module Configuration Failure ABS Module CONFIGURE the ABS module. REFER to Section 418-01 . CLEAR the DTCs. REPEAT the self-test. If DTC B2477 is retrieved again, INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module . REPEAT the self-test. B2734 Pedal Travel Sensor Supply Error ABS Module Go To Pinpoint Test M . B2736 Pedal Travel Sensor Circuit Fault ABS Module Go To Pinpoint Test M . B2737 Pedal Travel Sensor Jammed Error ABS Module Go To Pinpoint Test M . B2738 Pedal Travel Sensor Velocity Error ABS Module Go To Pinpoint Test M . B2740 Pedal Travel Sensor Spike Error ABS Module Go To Pinpoint Test M . B2741 Sensor Cluster Defective ABS Module FOLLOW the diagnostic tool directions for the calibration procedure. B2900 VIN Mismatch ABS Module VERIFY that the module has the correct as-built data.
    CHECK for correct powertrain control module (PCM) and ABS module configurations using the diagnostic tool. RECONFIGURE the component as necessary. FOLLOW the diagnostic tool directions for the ABS module configuration or REFER to Section 418-01 for the PCM. CLEAR the DTC. REPEAT the self-test. C1095 ABS Hydraulic Pump Motor Circuit Failure ABS Module Go To Pinpoint Test D . C1145 Speed Wheel Sensor RF Input Circuit Failure ABS Module Go To Pinpoint Test E . C1155 Speed Wheel Sensor LF Input Circuit Failure ABS Module Go To Pinpoint Test E . C1165 Speed Wheel Sensor RR Input Circuit Failure ABS Module Go To Pinpoint Test E . C1175 Speed Wheel Sensor LR Input Circuit Failure ABS Module Go To Pinpoint Test E . C1233 Speed Wheel LF Input Signal Missing ABS Module Go To Pinpoint Test F . C1234 Speed Wheel RF Input Signal Missing ABS Module Go To Pinpoint Test F . C1235 Speed Wheel RR Input Signal Missing ABS Module Go To Pinpoint Test F . C1236 Speed Wheel LR Input Signal Missing ABS Module Go To Pinpoint Test F . C1277 Steering Wheel Angle 1 and 2 Circuit Failure ABS Module Go To Pinpoint Test G . C1278 Steering Wheel Angle 1 and 2 Signal Faulted ABS Module Go To Pinpoint Test G . C1279 Yaw Rate Sensor Circuit Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C1280 Yaw Rate Sensor Signal Fault (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C1281 Lateral Accelerometer Circuit Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C1282 Lateral Accelerometer Signal Fault (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C1285 Booster Solenoid Circuit Failure ABS Module Go To Pinpoint Test I . C1287 Booster Pedal Force Switch Circuit Failure ABS Module Go To Pinpoint Test J . C1288 Pressure Sensor Main/Primary Input Circuit Failure ABS Module Go To Pinpoint Test K . C1440 (with stability assist) Pressure Sensor Main/Primary Signal Faulted ABS Module Go To Pinpoint Test K . C1516 Roll Rate Sensor Signal Fault (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C1517 Roll Rate Sensor Circuit Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C1730 Reference Voltage Out of Range (+5V) ABS Module Go To Pinpoint Test L . C1805 Mismatched PCM and/or ABS-TC Module ABS Module CHECK for correct PCM and ABS module configuration using the diagnostic tool. RECONFIGURE the component as necessary. FOLLOW the diagnostic tool directions for the ABS module configuration or REFER to Section 303-01 for the PCM. CLEAR the DTC. REPEAT the self-test. C1963 Stability Control Inhibit Warning ABS Module This DTC is for information only. GO to the Principles of Operation. CLEAR the DTC. REPEAT the self-test. C1991 Module Calibration Failure ABS Module Follow the diagnostic tool directions for the calibration procedure. C1996 Active Yaw and/or Roll Control Disabled ABS Module This DTC can be set if the ABS module system is activated for 15 seconds of continuous operation. CHECK for any major chassis modifications, gross suspension misalignment or other items that can alter the vehicle tracking dynamics. CLEAR the DTC. REPEAT the self-test. C1998 Module Calibration Not Complete ABS Module Go To Pinpoint Test O . C2769 (ABS only) Longitudinal Acceleration Sensor Electrical Failure ABS Module INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. CLEAR the DTCs. REPEAT the self-test. C2769 (ABS with stability assist) Longitudinal Acceleration Sensor Electrical Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C2770 (ABS only) Longitudinal Acceleration Sensor Plausibility Failure ABS Module INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. CLEAR the DTCs. REPEAT the self-test. C2770 (ABS with stability assist) Longitudinal Acceleration Sensor Plausibility Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C2777 Sensor Cluster Bus Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . C2778 Sensor Cluster Power Supply Failure (Sensor Cluster Fault) ABS Module Go To Pinpoint Test H . U1900 CAN Communication Bus Fault-Receive Error Network Fault REFER to Section 418-00 . U1901 CAN Network #2 Communication Bus Fault-Receive Error Network Fault Go To Pinpoint Test H . U2023 Fault Received from External Node Instrument Cluster REFER to Section 418-00 .
Oct 22, 2017 | 2000 Ford Expedition
2006 ford crown vic abs code b1596
B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart.
Anti-Lock Brake System (ABS) Module Diagnostic Trouble Code (DTC) Index DTCs DTC Caused By Description Action B1342 ABS Module ECU is Defective INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. B1484 ABS Module Brake Pedal Input Open Circuit Go To Pinpoint Test D . B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart. B1676 ABS Module Battery Voltage Out of Range Go To Pinpoint Test E . C1145 ABS Module Speed Wheel Sensor RF Input Circuit Failure Go To Pinpoint Test B . C1155 ABS Module Speed Wheel Sensor LF Input Circuit Failure Go To Pinpoint Test B . C1165 ABS Module Speed Wheel Sensor RR Input Circuit Failure Go To Pinpoint Test B . C1175 ABS Module Speed Wheel Sensor LR Input Circuit Failure Go To Pinpoint Test B . C1222 ABS Module Speed Wheel Mismatch Make sure the tires are the same size and correctly inflated. INSPECT the wheel speed sensor rings. CLEAR the DTC. TEST drive the vehicle. REPEAT the self-test. C1266 ABS Module ABS Valve Power Relay Circuit Failure Go To Pinpoint Test K . C1296 ABS Module Wheel Speed LF Signal Fault Go To Pinpoint Test C . C1297 ABS Module Wheel Speed RF Signal Fault Go To Pinpoint Test C . C1298 ABS Module Wheel Speed RR Signal Fault Go To Pinpoint Test C . C1299 ABS Module Wheel Speed LR Signal Fault Go To Pinpoint Test C . C1300 ABS Module ABS Hydraulic Pump Motor Circuit Failure Go To Pinpoint Test A . C1805 ABS Module Mismatched PCM and ABS Modules Do Not Match CHECK the part numbers. INSTALL the correct module. C2775 ABS Module TC ON/OFF Switch Stuck Failure Go To Pinpoint Test H . U0073 CAN Bus Control Module Communication Bus Off REFER to Section 418-00 . U1900 CAN Bus CAN communication Bus Fault - Receive error REFER to Section 418-00 . U2023 CAN Bus Fault received from External Node REFER to Section 418-00 .
Jan 14, 2013 | 2006 Ford Crown Victoria
Fujitsu seimens scenic p300 no chipset drivers where can i get them from
Specification Processor:
Celeron
Intel P4
up to 2GHz
up to 2.66GHz
up to 2GHz
up to 2.66GHz
up to 2.4GHz
up to 3.0GHz
up to 2.6GHz
up to 3.2GHz Motherboard: D1451 D1521 D1561 D1761 Chipset i845GV i845GE i865G SiS661FX Video: On-board On-board + AGP slot On-board + AGP slot On-board + AGP Slot Max Memory 1GB DDR333* 2GB DDR333 2GB DDR** 2GB DDR Memory slots 2 2 4 2 Audio STAC9750 AD198x AD198x Realtek ALC655 On Board Lan AN983B 82562ET 82562EZ AN983N Hard Disk: Depends on choice at time of purchase - 20/40GB (5400rpm), 20/40/80GB (7200rpm silent). CD/DVD Drive: Depends on choice at time of purchase - Cdrom ,DVD or CDRW * 2GB (DDR333) with future memory modules
** 4GB (DDR333/400) with future memory modules
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/professionalpc/Scenic/ScenicP/scenicP.htm
You know, if you can decipher your motherboard, You'll be able to find the intel chipset and do a download. Make sure you save/rename your old.
Apr 18, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu Plasmavision 42" TV Logo
117 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
