Question about Philips DVD953AT DVD Player
My DVD, when switched on makes buzz/rattle noises.
Hi HELP! I was playing a movie the other day and it just stopped. I hit open on the player draw and after about 5 mins it opened. I have a look at the disk and theres nothing wrong with it. I tried to close the draw and again after about 5 mins it closed - straight away it started making loud buzzing/rattleing noises. The display panel just shows lines like " - - - - - " . I don't think the disk is the issue. Anyone out there help me? Dublin, Ireland.
  • Dave Derek Sep 27, 2006
    Thanks! I'll give it a try. Fingers crossed!
    President:
  • 3,130 Answers
This could be a lot of differant issues. First thing I would do if your a tech or know how to troubleshoot solid state elctronics is try the easyest thing first like unplug unit for 12 to 24 hours. then open the unit and check for ripple on the b+ lines. if the power supply is good i would then check the slider as well as the return home/park switch. The make sure that the slider does return to home and that the drive Ic for the motor is not over heating. If you cannot make these checks then the only thing you can do is try the reset like I said as it most likly will not be worth the bench charge to invest into this unit. thats the way these things are built, a throw away sociaty
Posted on Sep 27, 2006
Hello, I have a liteon inc ihes212 blueray combo. The dvd tray will open by itself at computer shutdown and startup. sometimes it will do it at comouter sleep mode. My system is windows 7 home premuem
Usually when a drive exhibits the symptoms you describe it is defective and not economically repairable. I believe many of us have had a similar experience.
Nov 11, 2013 | Lite-On Inc LITEON IHES212 Blu-ray Combo...
Unit model specified doesn't play DVD
Need to install a DVD proggy like Power DVD or Interactual player to view DVD's
these DVD softwares are got in NET in many sites
Dec 25, 2007 | NEC ND1100A Internal IDE DVD-RW 4X+ Drive...
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
Buzzing noise from TV when playing DVD/Photos
Usually this noise is the result of a bad cable. Unplug to see if noise goes away. If so, try different cables.Has solved that problem for me several times over the years.
Dec 19, 2017 | Sony BDP-BX2 Blu-Ray Player
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
Dvd stopped playing in the middle of a movie...
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial dvd that you attempt to play, the unit is defective and needs to be replaced. Hopefully, since it's brand new, you still have the receipt and can return it to the retailer for an exchange or refund. The unit has a 90 day warranty from the date of purchase. You would need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 28, 2008 | Coby DVD-224 DVD Player
I NEED HELP IN STOLLING MY NEW DVD PLAYER
good day,
just make sure that the colors are matched with the jock and the socket in your dvd player and your tv. just make sure that you unplug first your dvd player and tv while attaching the wires to avoid accidents.
just follow the color coding of the wires and cables and you wont go wrong. just plug in the your tv and dvd player to the electric socket and in no time you will be watching your favorite movie.
for the player, just press the open(eject) button to insert your dvd and normally it will automatically play. just hit rewind (<<) for playback and forward (>>) to skip some scenes. use the |<< button to go back to a previous section and the >>| to skip to the nest section. use the || to pause and the button with the square symbol to stop.
i hope this would help.
Oct 09, 2008 | Televison & Video
Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Jun 06, 2008 | LG DP781 Portable DVD Player
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Philips DVD953AT DVD Player Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
