Question about RCA Televison & Video
My ant2000 has gone through short scan and full scan and still no channels found. 49 for converter box and 64 for smart antenna and still no damn channels. why is this? both tv and box are on ch. 3
3 Suggested Answers
bobjrdns
  • 84 Answers
SOURCE: trying to install an rca
NO IF USING A ANTENNA YOU HAVE TO SWITCH THE TV FROM CABLE TO TV IN THE SET UP
Posted on Oct 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: i BOUGHT A CONVERTER ANT2000
One thing you could try is to get an amplifier for your antenna. There available at Radio Shack and other electronic stores. The amplifier plugs into an electrical outlet. The antenna coxial connector plugs into the input of the amplifier then you take another coax wire and run it from the converter to the output of the amplifier. Then try pointing it around to see what you get. Your antenna should be approved for digital TV use as well.
I've heard that digital tv is a little more precise to get than the analog. One source you can use to find out what direction the tv transmitters in your area are pointing at is:
http://www.fcc.gov/fcc-bin/audio/tvq.html
Type in the call letters of the station to see where the transmitters are located. This is very detailed information on this page.
Posted on Oct 27, 2008
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Channels
Depending on your location and the type of antenna. If you are on the converter box when you scan for channels, how many do you receive? If you go back to analog or the way you were set up before how many stations did you receive? Some stations have not gone completely to digital as of yet. Other stations are in process and are not to full power for digital as of yet. With the box you may have to rescan every week or so until everybody gets their act together.
Feb 02, 2009 | Philips Magnavox 20MT133S 20" TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
I bought an RCA 800 converter box and it keeps saying signal is too weak, so I bought a stronger antenna. It didn't work and the manual says I need a smart antenna. I bought the RCA antenna 1500. This is...
try this:
if the antenna is the kind that takes a power adapter to power try moving it away from the converter box and try changing frequeny on antenna this problem is usually for cbs channels...
Nov 12, 2008 | RCA Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
