Question about EliteGroup P4VMM2 Motherboard
Monitor and cpu problem
Monitor standby when video card plug in
Sometimes the videocard software is not installed properly or it is not supported.
Posted on Nov 04, 2008
NO DISPLAY IN DESTOP, CPU FAN IS WORKING ,
Try re-seating the video card.
Check the video cable is plugged in tightly on the video card and monitor.
The video cable maybe faulty, try a different video cable.
The monitor maybe faulty, try a different monitor.
Sep 23, 2012 | Computers & Internet
TFT185W80PS monitor is not working
Check if your monitor power led indicator is on if it is, try to check the cables of your monitor if it is properly plugged to your CPU if it isn't plugged it properly if the problem still doesn't solve try to open your cpu and and uninstall your video card if you have a separate one and clean it with a pencil eraser then install it again and try it if it will work. But if your video card is built in, there is a problem with your video card or maybe your monitor try to contact a reliable computer technician..Hope it will help you.
Jul 02, 2011 | AOC widescreen 931SWL LCD TFT 19" Monitor
The cpu is running,the motherboard is with green light inside,but the monitor blanck
what king of monitor you have., crt or LCD, does the monitor led indicator has a green light, is there any beep when starting the cpu? how many beeps you have heard when the cpu was starting?.
if there is no led indicator light in you monitor the posibilities of that is the monitor was the problem.
solution: try to check your plug in monitor if it is properly inserted in the power plug or in the vga plug correctly.
if when you power the cpu and your monitor led indicator, turn green and back in the standby mode. listen to the beep sound of cpu if theres any.
solution: try eject the mem card. in the slot and clean the contact with the eraser. and put it back into the slot again after you clean it.
Mar 28, 2011 | Computers & Internet
All the cable are connected correctly and power turned on, but when i start the computer, the computer itself seems to come on ok, but when i turn the screen on it says 'power saving mode' and seems to go...
Does your PC has plugged in video card, you can try reseating it first? If it has integrated video card in the mother board, then there may be not much you can do.
Did you install any new software or update any drivers?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 19, 2010 | LG W1934S-BN 19" Monitor
My Compaq Presario SR1010NX is freaking out. The screen lettering streaks and gets jumpy. I need to find out if its the CPU or the monitor. I feel the CPR needs some sort of upgrading or replacement part...
If you want to test the monitor. plug it into another computer. Most likely its the video card on the computer and not the CPU. CPU's dont give you lettering streaks. Also try plugging your computer into a different monitor. If it is still streaking then it definitely is the video card and in that case just replace the video card.
Mar 23, 2009 | Compaq Presario SR1010NX (DW254A#ABA) PC...
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor on Standby / NO picture / all fans ON highest level
dear sir
here as u say the problem is actuly not a video card problem some time power plug or power connector problem make yr pc problem first u need to chek power connecter or power cable is ok or not then try to clean RAM if dust jam on ram that time it's not display and last on list is chek yr cpu fan is conneted propper or not yr pc has a AMD proceaser so it need to cool it's help u..:)
if u try to perchase new video card then u need PCI express card..
thanks
please Vote
jo_chinmay
Jan 01, 2009 | E-Machines T6420 PC Desktop
Intel D945GTP monitor going into standby, cpu fan runnning full blast
your cpu might be overheating..it might be defective..if you have no video output it means ur ram or your cpu is bad
Oct 28, 2008 | Intel D945GTP Motherboard
Motherboard Problem
Were all these working fine together before or did you just replace something? Did you try connecting the monitor to another PC? Try the pc on another monitor which works. try unplugging the video card and plugging it back in. try without the memory, it should post and beep looking for the memory. try without the harddrive.
Apr 02, 2007 | Chaintech Slot 1 CT-6ATA2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
43 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
