Question about HP Compaq nc6000 Notebook
Keyboard 10 key, digits aren't working, just the symbols
On the "10 key" all the symbols work just fine but the numbers 1 - 0 don't. I tried buying a new keyboard twice, both the wired and also wireless type and both acted the same so I assume something happened in the program, but, I've probably talked to at least 6 different so called computer experts and nobody seems to know how to solve my problem. I have an HP and run windows XP and while I've always done well with everything else this has me baffled. I know just enough to be dangerous so don't really have any idea what else to look for.
  • 849 Answers
It is sure that keyboard has not any problem, check the foloowing:-
application configuration
setup configuration
virus
shift key pressed
Posted on Nov 03, 2008
My at symbol and others do not work. how can I fix this please?
Catherine, Try compressed air to blow dust and debris from key board, try a system restore to an earlier date, you could also try re installing key board/driver, you may also have faulty key board and need to replace..
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Some Keyboard Keys not working
Not all keys on keyboard work
Some of my keyboard keys aren working
Aug 07, 2016 | Logitech Computers & Internet
Cannot use shift key + number for numbers 1 through 4 and 7 through nine.Cant make any symbols(at sign,exclamation sign).I tried reinstalling keyboard driver,choosing different language,so on and so...
You might have a hardware issue with your laptop keyboard. You have at least 2 options:
1) connect a "normal" USB keyboard to your laptop and use it, instead
2) run the On-Screen Keyboard (osk.exe) and access the characters/keys you want from there
Good Luck!
Oct 18, 2013 | HP Pavilion dv9000z Notebook
Numeric key pad on right wont work on aspire 7741 notebook
Maybe you need to press the Num lk (number lock) key at the top of the keyboard, then Press and Hold the FN function key at the lower left portion of the keyboard then hit the number key you want..
May 06, 2012 | Acer Aspire 7741z
The number and symbol keys above the letters on my Dell keyboard don't work... What do I need to do?
Please restart your computer at once. If it doesn't work check the Keyboard cable from your computer. thanks
Aug 29, 2011 | Dell Keyboard/Mouse
My keyboard is working fine but my enter key or return key as they say and shift key below the enter key isnt working.
If there is a mechanical fault there is not much you can do. If other keys are working then there definitely is a mechanical fault. Some crafty expert has to remove those keys and find out what the problem is. There can be broken brackets underneath or there might be some drops of liquid food congealed underneath the keys. Only the person who will open the keys will find out first.
Jul 22, 2011 | HP Mini 1000 Netbook
On the number pad the number 0 does not work, the arrow keys do not function any more. All was fine until the keyboard was cleaned. Multiple keys were hit at the same time and now this is what happened?...
Go buy a new keyboard for less than $10. It is not worth the effort to try and fix. You can take a keyboard apart and clean and fix it, but for less than $10?
Good luck
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 23, 2010 | Dell 0Y3740 Keyboard
Keyboard issues
Press the "Number lock" key.
Apr 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
Keyboard don-t show the correct symbols
Your keyboard setting in Control panel regional and language options is probably set to US International.
This option allow you to create every special character using combined keys see this page for MS instruction>
If you have a localized keybord (Portuguise, Brazilian or else) you can get the symbol corresponding with keys if you configure the exact keyboard instead of US international.
Of course for same language you can configure multiple keybord.
You can also use for every language the On screen Keyboard you get in Start/program/accessories/ accessibility
Feb 10, 2009 | Computers & Internet
Keyboard problems
yes in some issues i have encountered the ribbon that plugs the keyboard in may be corrupted or you may have a bad keyboard
Aug 10, 2008 | Samsung P10 C XTC 2000 Notebook
Recently, numbers 1 to 4 on keyboard won't work.
This is only a --temporary-- solution.
I have the same problem, with only the numbers 5 and 6 working. My temp solution is to use the character map, located at START -> Programs -> Accessories -> System Tools -> Character Map. If you don't have one, you can do a search to download a free one.
May 25, 2008 | GE Office Keyboard HO98056
HP Compaq nc6000 Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
