Question about Dishwashers
Dishlex Global 300 won't drain
This d/w is about three years old. No problems with it so far. Recently though, the clean is not very good. Residues are left on the dishes and it won't drain.
I've got the arm and filter removed, however there's a pool of water in the cavity in the floor of the d/w. I could drain this using a pump, but how do I get rid of the blockage (if that's what it is) leading into the drainpipe?
The first time I had this problem with our Global 300 was because a number of small cherry pips had managed to get through the filters and to the drainage cavity, hence jamming the drainage plug.  I fixed it by first removing all the lower filters and hand-draining the excess water with a small cup and then a sponge.  There are another two plastic parts screwed into the metal dishwasher frame (one inside the other).  Next step is to use a phillips-head and unscrew the middle part (3 screws) and remove.  Then I used my finger to prod inside the bottom left hole of the other plastic part (its quite awkward to get to), and you should be able to feel the plug.  Play around with it until you can feel it move 5mm or so.  It should be right now. Replace all the parts and see if it works.
This problem has happened to me a number of times since, and it seems to coincide if I have "shorted out" the electricity supply by using too many other appliances, or have opened the dishwasher mid-cycle.  So its like the plug is warm and sticky, and the dishwasher finds it hard to release.  I can usually fix the problem by going through the above procedure.  I actually think it has something to do with wear and tear on the plug rubber ring from the detergents, and that it might just get stuck on the wall of the dishwasher hence not allowing it to release and drain.
Its happened again tonight, and we've fixed it once.  I've added some vinegar now in the hope it will dissolve the excess detergent sitting in the system.
Posted on Dec 05, 2008
Thanks Rosa K, problem solved! Saved me a call-out, which can be quite expensive.
Unfortunately, I've had to repeat this procedure a number of times. Nonetheless, each attempt has got the dishwasher working.
I'll give it a bit more time, but eventually I'll turf it and steer clear of this brand of dishwasher. It's given me more trouble than it's worth. Thanks for your solution.
Posted on Nov 09, 2011
    New Friend:
I had this exact same problem with my Global 300 and the fix was to detach the drain hose where it connects to the drain under the sink or where ever it goes to and blow back down the pipe. You need to do these while the washer is trying to drain, you should hear the rumple noise when it is trying, but you will have to attach it back on pretty quick as the pump will kick in and start pumping again when you do this.
I spend ages trouble shooting this issue i even pulled the drain pump out and connected power to it to see if it was working and couldn't find anything wrong with anything.
My theory is, there s a small rubber valve that should fall shut on top of the drain pump after it finished draining, i don't think this was coming back down again and it needs to, to create a vacuum or something. its possible that the sponging process getting the water out from the inside could 'pull' it back down too, but this is much easier as you only have to take off a pipe
Hope this helps someone
Posted on Mar 24, 2016
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
My detergent cup doesn't open on my Dishlex Global 300 which is 11 years old. I read a solution here that there are three things that are often the cause for this to happen: -There is a problem...
Troubleshooting them can be time consuming and frustrating....be careful when calling a repair guy as many are just parts changers and you'll end up spending a ton of money with no results...
heatman101
Sep 15, 2011 | Dishwashers
Dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
May 22, 2011 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Global 300 Dishlex draining problem
is the float switch clear of debris so it can go down to its lowest point to shut off the pump,, a peice of food could be stuck in it, keeping it up just enough to keep it running
Jan 03, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
1,009 people viewed this question
Top Dishwashers Experts
