ASUS P5LD2-VM Motherboard
Problem for ASUS P5LD2-VM Motherboard
USB2 high speed not recognize
By Yaron on Sep 27, 2006
My machine has professional XP with service pack 2.
I can see in the device manager the USB2 but when I plugin a USB2 device (HD or card reader) I recieved an error saying:
"This device can perform faster if you connect it to a Hi-speed USB 2.0 port"
I updated the Bios but no louck.
Is there away to set it up for USB2?
Comments:
Sep 28, 2006
- Thianks for the reply,
Using the Device Manager I can see one of the USBs as "USB 2.0 Enhanced Host Controller"
Does this say I already have the driver for USB 2.0?
Thanks
Oct 03, 2006
- Any USB2 device I plug in shows the same error.
Feb 28, 2007
- After a while I had some other odd cases (mouse did not work) so I gave the machine for technician.
He found out that the motherboard was fault.
We replaced the motherboard (to new one, the same model) and all is working now.
Thanks to all.
Same Problem
Feb 19, 2009
-   hi there i have a new motherboard and pc really when i add my modem dongle it says can run faster if i cinect to a highspeed port but the man in pc shop says my board came with high speed so why the warnings? plz help driving me mad
-   Guest
Jan 03, 2009
-   i need usb 2.0 for asus p5ld2series(xpsp3)
icq 365791840
-   Guest
Nov 04, 2008
-   ihave USB2 high speed not recognize problem-   nazarielec
Oct 10, 2008
-   Yes Hi.. I have P5LD2 -LGA, and I get the same message "will perform faster with usb2." In addition, my usb devices (camera, mp3 player) will not function depending on which USB port I connect it to. I have updated the current drivers and BIOS for the motherboard, which actually has really nice applications to adjust overclocking, monitor MB and chip temperature, ect. Anyways, did you find it that replacing was the only option?-   chewible
Sep 12, 2008
-   I get the same error message - USB High Speed pluged in but no USB High Speed Port found on the computer.-   Walleh
Solution #1
posted on Sep 29, 2006
Very Helpful)
goomf
Rank: Apprentice
Rating: 100%, 2 votes
Hi, I have a similar problem, I too run Windows XP sp2 and the message I get when plugging in an USB device is that a high speed USB device is plugged into a non hi speed USB port. When trying to reinstall the USB driver, I get a message saying that the latest drivers are already installed, it won't let me unistall either. I have the latest BIOS installed also. This message appears with ANY USB2 device attached. I also have a seperate card plugged into the motherboard for additional USB ports, the message appears when I plug into them as well. Any suggestions?
Was this helpful?
Yes
No
Solution #2
posted on Feb 28, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks to all.
Solution #3
posted on Sep 27, 2006
Helpful)
habib_101
Rank: Wiz
Rating: 79%, 458 votes
It sounds like your Windows XP might be missing the USB2 drivers. Try going here http://www.windowsmarketplace.com/ and download the driver needed and see if that fixes your issue.
Comments:
Sep 28, 2006
- Interesting. From that it's showing that you do have the correct driver. So, any USB2 device you plug in will give you the same error?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jul 10, 2007
Somewhat Helpful)
anarchy
Rank: Apprentice
Rating: 72%, 4 votes
in the bios dont enable full speed only high speed, or the other way round. had that problem lastnite where my mouse and usb's werent working so i changed the bios settings and walla everything was fine.
Was this helpful?
Yes
No
Solution #5
posted on May 20, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this motherboard not support USB2
Solution #6
posted on Sep 18, 2009
Not Rated)
gkruck01
Rank: Guide
Rating: 100%, 6 votes
I was getting the same "This device can perform faster..." message as the original poster, even though the Biostar motherboard supported USB2.0. I checked the bios, and updated the drivers. No difference. The PC eventually (three months past the one year warranty expiration, of course) just wouldn't boot, so I took the processor box in to a tech and it was, as with the original poster, the motherboard. And, of course, the new motherboard didn't have an AGP slot for my graphics card, and I needed new memory chips. Yes, "Dogtags," we are getting old really quick these days. I've got a MagicJack phone hooked up also, and the sound is much cleaner and consistent than with the old board.
Was this helpful?
Yes
No
Solution #7
posted on Jul 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Please pay attention that Asus P5LD2 motherboard has USB2.0 (HI SPEED USB) disabled in BIOS by default! (advanced/USB configuration). I solved my problem with USB 2.0 recognition by just enabling it in BIOS.
Solution #8
posted on Nov 12, 2007
Not Rated)
Dogtags
Rank: Apprentice
Rating: 0%, 0 votes
I had the exact same problem, my mouse just quit working! I've tried EVERYTHING! It's getting really hard to find this board to replace cause of all the new computer components. I don't want to lose the money i got pumped in this board, Maxed out the CPU 3.4g, memory DDR400 (4 gig). I cant use those in a new Motherboard, they change the chip set's too fast, and everything is now PCI-Express & DDR2! Maybe I'm just getting old really quick :(
Was this helpful?
Yes
No
Solution #9
Not Rated)
lucky4lynn2
Rank: Apprentice
Rating: 0%, 0 votes
I was reading your complaint and can relate... I am having the same issue as you. As well as another error message warning me that my USB ports are EXCEEDING THEIR POWER LIMIT-- "POWER SURGE ON USB PORT!!!" I've tried all kinds of things.. nothing works.. Finally I had to disable the device. I can enable it and can upload my pics off of my Digital Camera just fine.... But try and use it for my Wireless Modem?!?!? NOOOO WAY... The two error messages take turns going back and forth over and over. Frustrating....
Was this helpful?
Yes
No
Popular Solutions for ASUS P5LD2-VM Motherboard
Questions and Unsolved Problems for ASUS P5LD2-VM Motherboard
Do you recommend ASUS P5LD2-VM Motherboard?
Answer
Answer
how do i unlock channels on an ntl set top box?
Answer
CANT,TRACE POWER INPUTS ON BOARD REVAOO
Answer
Erroe asking me to return tray to normal postion and press reset buttun resume printing
Answer
i have anorthgate motherboard SV266M and i need drivers...video and netowrk etc etc
Answer
How do you install a performance chip on a 2003 audi a4 1.8t
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 19, 2008
high speed usb 2
Comment by Guest, posted on Dec 24, 2007
Using the Device Manager I can see one of the USBs as "USB 2.0 Enhanced Host Controller"...After a while I had some other odd cases (mouse did not work) so I gave the machine for technician. He found out that the motherboard was fault. We replaced the motherboard (to new one, the same model) and all is working now.
Comment by Guest, posted on Dec 23, 2007
Comment by Guest, posted on Nov 18, 2007
Please describe the specifics of your problem below. We'll add
your post as a comment to Yaron's USB2 high speed not recognize problem, and notify you when a new solution
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS P5LD2-VM Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
