Question about Orion VR213 VHS VCR
Manually setting vcr
I have an Orion VCR, and would like to know if there is any way to manually set the speed of recording. It uses a 6 hr tape in 2 hrs. I am not interested in ordering a remote. Thank you!
  • hughesn_15 Nov 16, 2008
    I have the same problem and I have a remote. I set the programs and set the speed to SLP, but it doesn't work. The only thing I don't have is the instruction booklet to tell me what to do to make it work, afterwards. Please help.
  • Orion Master
  • 520 Answers
I'm sorry but, there is no way to set the speed without the remote. Last time I checked a remote for a VR213 was less than $15.00 delivered. Just FYI. If you change your mind call the number on the unit. Sorry. No magic bullits.
Posted on Nov 05, 2008
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
My vcr tapes play too fast
If I remember correctly, VCR players had three speed settings. SP-short play, LP-Long play, and SLP- Super long play. The vcr is supposed to be able to tell what speed the tape was recorded at, thus playing it back at the correct speed. If your unit has lost the ability to sense the speed the tape was recorded then you will have to set the speed manually, if possible. Other than that I would have to say it's time to get a new vcr.
Feb 20, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Runs fast, only 5 hrs recorded on 8 hr tape. Any speed setting
check that you have the right type of tape, SRC-800's should record 8HRS with a T-160 tape.
May 08, 2009 | Sanyo SRC-800 VCR
Jvc a 55u plays a movie from the store but I cant get it to tape a regular tape,it's a nice vcr and I have never seen this problem, the moves from the store are played great but when I put in my own tape...
Hi Diane,
Just downloaded the manual for your vcr it says:
1 Press menu
2 press up/down arrows to Function Set then press ok
3 press channel up/down arrows to Auto picture then press Ok or shuttle plus right arrow to set to on or off when using rental tapes set either to on or off to give the best picture
4 to return to normal press menu
For recording
1 load a cassette make sure the tab on the cassette is intact if not put some cellotape over the hole
2 set channel press up/down arrows then press enter
3 select tape speed sp/ep
4 press and hold rec and press play on remote or just press record on unit
5 to pause recording (cut out ads) press pause on remote to continue again press play
6 to stop recording just press the stop button
hope this helps and reflects in my feedback lol all the best
Jim Scott
Feb 28, 2009 | JVC HR-VP693U VCR
Taping from surveillence cameras
the vcr has to be set to moniter the camera!...buy a cheap universal remote and push monitor in the menu screen!
Dec 10, 2008 | Orion VR213 VHS VCR
Orion vcr recording
I'm sorry, but the speed cannot be changed without the remote.
Nov 07, 2008 | Orion VR213 VHS VCR
Recording issue
if it is really old there might be a switch on the front under the little door to switch record speeds.
Apr 24, 2008 | RCA VR615HF VHS VCR
Orion VR213 VHS VCR Logo
400 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
