Question about HP iPAQ RX3115 Pocket PC
Ipaq RX 3115 Stops at align Screen
One day I notice that my Ipaq RX 3115 was locked up. After doing a soft boot on the ipaq, it starterd to re-set itself. At the align screen I click on the + to set up the screen, the Ipaq will not go pass this screen, it keeps going into a loop. I have tried a hard re-set and removed the battery from the ipaq, but still it will not go pass the align screen. When I hook the Ipaq up to the PC, the PC sees it, setup the partnership with the Ipaq and activesync. But still can't get pass the align screen.
  • 4 more comments
  • SmoothSolja Dec 03, 2007
    i haved the same problem mine will not go past the align screen no matter how many times i do it its stuck on it i tryed everything but i juss dont know how to fix it? any help with that?
  • Hiep Tran Dec 17, 2007
    i have exactly same problem,my rx3115 stucks at align screen
  • reeeyaan Dec 19, 2007
    same problem with the align screen here.
  • Big Johnny May 23, 2008
    My iPAQrx 3115 and an older iPAQ locked up at "Align Screen". I tried soft and hard reset, changed batteries, except throwing if against the wall. Nothing seen to work. What do I do next?
  • Eminacool Oct 03, 2008
    my pda wont go past the aligh screen. it's driving me CRAZY!!!!!
  • drhigbee Feb 15, 2009
    After a hard reset, I cannot go past the align screen.  It keeps recycling the same screen.
Posted on Dec 04, 2008
Alright thank you.
Posted on Dec 03, 2007
  • 537 Answers
Solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
SOURCE:
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
Feb 17, 2009 | HP iPAQ RX3115 Pocket PC
Ipaq rx-3115 stops at align screet after reset
Sounds like u need a replacement LCD
Easily found on ebay
Replacement screens usually come with instructions.
Please note u will need a hollow t8 or t9 tool to open the ipaq case.
PIM ino lost from ipaq 1950
did a hard reset. booted up ok. did activesync with my other PDA onto computer and then sync'ed with 1950.
Dec 01, 2008 | HP iPAQ rx1950 Pocket PC
Screen is locked
Mine hp ipaq also froze up, but I tapped the screen until they moved around all in alignment, and I got the basic things back (my programs, Media Player etc. but I can't sync it with my computer. It doesn't recognize the name of my handheld.
Aug 04, 2008 | HP iPAQ HX2755 Pocket PC
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
Ipaq rx3115 doesnt turn on!
I am guessing that you have made sure that it is fully charged. If it is, since you have only had it a week I would try a hard reset. I don't know if the 3115 has them but check to make sure that any battery door lock switches are locked.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
IPaq keeps moving appointment times
the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
Charging
If it's completely dead USB probably can't do it at all. There's a voltage threshhold, and USB only puts out about half the voltage needed to get over it. USB usually won't manage when thenbattery's below 30%. Try connecting the iPaq directly to the AC adapter.
Rx3115 locking up
To execute a hard boot on the iPAQ rx3115, the manual says to "while pressing the two outside buttons on front of iPAQ, press the recessed reset button on bottom." Hope it Helps... Wirzan
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
733 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
