Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
LG Rear Projection TV RT- 48SZ40RB
I recently changed the lamp but dont know how to re-set the lamp hrs to get the orange light to go away. Can anyone help?
Some say you can reset the timer in the service menu, normally accessed by holding down the menu button on the TV and the mute button on your remote at the same time. Others say you need a special "service remote" to access the timer. I've changed my bulb twice already and have just learned to ignore the amber lamp timer light. A little square of black electricians tape would make it go away!
Posted on Nov 11, 2008
LG 52" Rear projection TV
Probably something wrong with the lamp. Buy a replacement.
Mar 01, 2011 | LG RU-52SZ30 52" Rear Projection...
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
LG Rear Projection 44" will not turn on
Make sure you reinstall the lamp door as there is a lamp door switch that must be closed or the unit will not fire the lamp, there should be a small hole or opening on lamp door housing. Some people install the lamp without reclosing the door just to see if the unit works , just to find out if it will not work, and when it does;nt think something is wrong, they do not put the lamp door back on first. Not to say this is the case but it does happen.
Jun 12, 2009 | Samsung HCN5527W 55" Rear Projection...
Lamp rest light
Press and hold the Mute button on the remote and at the same time press the Enter button on the TV until the Reset menu appears. Press Center button on remote to clear hrs. Your done!
May 27, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have a lg rt 52sz, lamp light flashed so i replaced the lamp, now when i turn the tv on the red light turns orange for 8 secnds then tv turns itself off, the lamp is still flashing. Signed unhappy...
make sure the lamp is in correctly and the door is also on good. there is a switch on the lamp door opening that wont let the set turn on if the door is not on.
Apr 24, 2009 | Televison & Video
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Same problem
hi there it sounds like a lamp problem i had the same trouble today i replaced the lamp cost me 190.00,
take the side cover off then the steel case inside, then 3 screws turn lamp arround and see if its damaged, hope this helps
cheers woodatoni
Oct 26, 2007 | LG RU-60SZ30 60" Rear Projection...
LG 211cm rear projection RT-48SZ40RB
the amber ight is a simple warm up procedure as it projection seems a power problem...
Aug 01, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
272 people viewed this question
Computer Repairing
Computer Repairing
