Question about Bogen Imaging NeoTec 458B Tripod
Leg won't extend
I have a nearly new Neotec 458B tripod and one of the legs won't extend. I'd like to fix it myself. Thanks! Eric,
Manfrotto 3051 Leg Section Slips After Locking - How To Disassemble you may need a new leg lock, you have to loosen it enough and the leg should come out. Send us some pictures at and we will probably be able to set you up with something.
Aug 07, 2012 | Photography
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
Locking tripod leg
Sorry, the mechanism and how it is put together should be repaired my Manfrotto. It has a one yar warranty when you bought it, and if you went to the Manfrotto website and registered it then the warranty is 3 years.
Jun 09, 2010 | Manfrotto 458B Neotec Pro Photo Tripod...
Hi,I have aManfrotto 458B and on one of the legs the quick release mechaniism isnt releasing have used lubbrication oil but as yet this does not seem to be working.
Because of the way the locking mechanism works inside the tripod I would recommend that you send the tripod back to Manfrotto / Bogen for repair. None of the parts inside the legs should be oiled, as the lubrication from the factory is enough. The parts not working is a symptom of a part being damaged or defective.
Manfrotto Distribution / Bogen Imaging Company
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
Jan 17, 2010 | Photography
I dont know how to extend the legs of my VCT MTK Sony tripod
That appears to be a mini tripod.. it is unable to extend the legs any further..
Feb 18, 2009 | Sony VCT-MTK Tripod
Vivitar tripod V900 has a broken friction level
Vivitar has been out of the tripod business for a few years now. They may no longer have the parts. You may be able to find another V900 and scavage the parts. Make sure the model numbers match exactly. The V900SE is a different year and does not share the same parts as the V900.
Jan 01, 2009 | Photography
Libec THM20
The leg is slightly off the track, which is a curved piece which fits along the tripod support rail. If you're not careful when collapsing the legs you'll force the leg to go off-track like this.
Sep 07, 2007 | Libec ST30 Tripod
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Bogen Imaging NeoTec 458B Tripod Logo
46 people viewed this question
Top Bogen Imaging Photography Experts
Are you a Bogen Imaging Photography Expert? Answer questions, earn points and help others
