Question about Olympus FE-190 Digital Camera
Picture Error I took a lot of pictures on my birthday, and only the first 9 work and the last 3. The rest say picture error. Is there anyway that I can recover my pictures? ughhh stupid camera.. it just knew which ones were my favorites..
  • 20 Answers
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
When i click a picture it takes lot of time 2 save the picture even if the card is not full.. like e.g i click the birthday blowing of candle i cannot instantly take picture of the cutting of the cake....
It is possible that the memory card is full, with little space for storage. Also it can have errors if the card was not cleared or formated.
So ideally it will be best to remove the card and use an adaptor to load into your PC, open and copy all the image files to a selected marked folder . Now after the images are saved you can scan the mamory card check the properties. Now you can get an idea of the card but it is best to have the card FORMATTED. This will wipe the memory clean and make it work faster on the camera. If not the camera processor has some errors.
Aug 22, 2011 | Kodak EasyShare C613 Digital Camera
File error
It is picture file that stops file transfer function, delete that picture and continue or go to memory card through my computer > mass storage drive and delete that file or copy rest of files and past in computer some where like my documents etc.
That particular picture file DSC03270.jpg is incomplete/ corrupted and causing problem in files transfer operation. Either delete it or bypass it and transfer rest of files from camera.
After transferring files to computer, format memory card to avoid any problem in next time as option would be in camera menu.
Let me know if you have additional question.
Thanks.
May 30, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
I have a S1500 I just got last month. I was taking pictures of a friend last night and two shots looked like they blew up by themselves and is was yellow. Next two shots was a smoke all around her. I...
Did you format the card in the camera before you tried to use it? Also, go into the menu and scroll to "reset" and follow the on-screen instructions.
Nov 14, 2009 | Fuji FinePix 3800 Digital Camera
Samsung SL310w Camera last day of holiday and Card error came up, can I retrieve my pics anyway. I had taken about 100 pictures. The card is and Optima SD 2GB which came with the camera. HELP PLEASE - PICS...
Take the card to a store that has a Kodak picture maker kiosk (like Walmart). Your pictures should show up and you can print them or even make a cd. After you do that, format the card in the camera before using it again.
Sep 17, 2009 | Samsung SL310W Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
File Error
i have the same problem too! ughh it so annyoing.
Feb 27, 2008 | Sony DSC-T70 Digital Camera
File Error
I also have the same problem
Dec 17, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Picture Error
Hi, It is possible that the memory of your camera got corrupted. You can try and format the memory and see if it will clear any errors and make the memory (card) available for use of the camera. Should you want to try and recover any images stored in the memory card, it has to be a removable one that you can plug in to a card reader attached to a PC. Run data recovery software to hopefully recover whatever you can from the memory. You can also format the memory with your PC and use a disk checking utility to check for any other errors. Thereafter, if things are ok, it will be ready for use of the camera. Hope this be of some use to you. Post back how things went or should you need additional information. Good luck and kind regards.
Aug 24, 2007 | Olympus FE-170 Digital Camera
Picture Error
It is a possiblity that the batteries were weak and caused the camera to shut off while saving the picture. Try using a card reader to load the picture into your rcomputer. I have run into this before and sometimes there is nothing that can be done to save teh picture.
Feb 02, 2007 | Olympus FE-140 Digital Camera
Olympus FE-190 Digital Camera Logo
259 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
