Question about HP Office Equipment & Supplies
The printer continues to print after cancel button is pressed.
    Guru:
  • 859 Answers
If this happens often and then eventually you are able to get back to work. I'll explain how these printers work.
When you send a print task to the printer, the data that is the construct for your document it resides on the printer in a temporary storage location called RAM. Once the instructions and the data are in RAM hitting the Cancel button will not have an effect until there is a break in the program execution to print. Sometimes nearly all the document will print before it cancels and this may take some time. The Cancel command must intercept a line of prgram execution. So just be patient.
If you need to immediately stop printing for some reason, the best thing is to pull the plug on the printer. Leave it unplugged for some time. As you put the power plug back in, press and Hold Cancel until the printer finishes the startup self check test, otherwise it may just pickup where it left off.
If this is a problem where no matter what you do, and the unplug replug while holding down the Cancel button doesn't clear your problem, unplug the printer again and look next to the digital clock at the bottom right of the PC screen. You may see an icon for your printer there. Double click that and you should see all the printer tasks listed in the printer que. Select all of those and then drop the file menu down and select cancel all or delete all.
Any question I didn't cover, please use the Text Box Comment area below to ask me another question.
Regards,
Worldvet
Posted on Nov 03, 2008
MUKHTAR
  • 2022 Answers
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Posted on Oct 06, 2007
  • 13 Answers
SOURCE: Service error 5100.
Had a same problem, here is what i ve received from canon support:
"Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
Please be advised that error 5100 indicates a carriage error and the machine will require service."
However I managed to solve it by myself by perform few paper path tests as there was a paper jam inside.
Posted on Nov 20, 2007
SOURCE: hp printer will not effectively cancel print
press start button, programs, administrative tools, services, scroll down to print spooler, double-click and press stop, right click printer icon on task bar, refresh, it should disappear. Double click printer spooler and start back up........ cancel out of everything. Job in quene should be gone.......
Posted on Aug 11, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: printer problem
the solution is that the waste inkt absorber is (almost) full. it needs to be changed
Posted on Mar 05, 2009
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Jan 17, 2015 | HP PhotoSmart 7260 InkJet Printer
My canon mx700 has stopped printing in color
Check the color cartridge to ensure there is is still color ink inside it, remove the color cartridge, shake it and fix it back, now try print, if did not still print color, i will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see problem.
Jul 01, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Printer will not print. I get an error code 5c00 on a MP530 printer
Try the following procedure:
hello
1)Turn off the printer.Press and hold the Resume/Cancel and Power buttons
at the same time.
2)Release the Resume/Cancel button.(continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button
3 times then release both buttons.
4)The LED should now be green.Press the Resume/Cancel button 4 times.The led
should be green.
Power it off and back on and you should be good to go!
do rate the solution
Nov 25, 2010 | Office Equipment & Supplies
Error 5800 on printer and when i try and print a page it says my absorbent tank is full
kindly follow this steps.1. Turn off printer.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
Nov 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full contact service center message
waste absorber full reset sequence for the I80.
1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time.
2)Release the Resume/Cancel button. (continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons.
4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green.
5) Turn the printer off and then back on. You should be good to go. Unfortunately when the tank gets completely full it will stop printing. The cost of repair however is more than the cost of replacement.
Jun 03, 2009 | Canon i80 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
180 people viewed this question
Ben Johnson
