Question about Whirlpool Dishwashers
Whirlpool Dishwasher Model GU2500XTPS1 Light on soak/scour button flashes on and off. Dishwasher will not run.
    President:
  • Whirlpool Master
  • 2,651 Answers
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
Posted on Nov 03, 2008
Clean light is flashing du1145 whirlpool dishwasher, will not run
This is a Common Problem. Read the same solution i offered to many Customer's and it actually worked like anything :-
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 11, 2010 | Whirlpool Dishwashers
Dishwasher will not run clean light keeps blinking
or
Hope i helped you.
Jan 10, 2010 | Whirlpool Dishwashers
Clean light flashing 7 times.
or
Hope i helped you.
Jan 06, 2010 | Whirlpool Dishwashers
Clean light flashing, won't allow cycle to run.
Ifthe clean light is the one flashing then your dishawasher could have aheater circuit problem (depending on the age) or this could simply justbe water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice andtry the dishwasher again making sure to run the water at the kitchensink till it is hot before starting the dishwasher, if this trips andlocks you have a problem with the heating element, or temp sensor.
Pressthe heated dry button followed by the normal cycle button, and thenrepeat once. You should see all of the lights come on for a second ortwo, and then the dishwasher will work again.
If you haven'talready, take a look under the kick plate in front to see if there is aschematic tucked in there somewhere. Whirlpool has put theirdiagnostics for specific models on these.
or
Hope i helped you.
Read the Testimonial by the one of the Customer's who had the same issue :-
http://www.fixya.com/support/t3124974-clean_light_flashes_7_times_time
Dec 30, 2009 | Kenmore 24 in. 16934 Built-in Dishwasher
Our clean light flashes 7 times pauses and flashes 7 times again, we can not restart the unit whats could be wrong
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
or
Hope i helped you.
Dec 30, 2009 | Whirlpool Dishwashers
Clean light flashes, washer won't run
or
Hope i helped you.
Oct 07, 2009 | Whirlpool Dishwashers
My soak/scour light is blinking and cant get my dishwasher to work. Any solutions would be greatly appreciated on how to fix the problem
generally any time a button continuously flashes, you either have a bad door switch that doesnt recognize door closing, therefore will not start, or the electronic keyboard/touch pad is shorted out, in which case youll need to replace the console assy
Apr 15, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
559 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
