Question about Mitsubishi Televison & Video
My old mitsubishi televison 52" manufactured in 1989 wants a 4 digit code to allow me to use my dvd player. i don't know the code.
  • 927 Answers
Try 0000
Posted on Nov 03, 2008
Dvd player resolution
what exactly does it say? that sounds like more of a tv setting...changing from 1080p to 720p or trying to play a blue ray in s standard player. Hmm..you need the programming codes for your remote. keep googling them...try these 1st... intertek is same as GPX i believe
0449, 0405, 0446 or 0936, 0944, 2114, 2390
*Remote program codes
Aug 30, 2017 | Televison & Video
I need to program the Fisher Price Inerac tv to the dvd and or the tv so I need the instructins on how to I lost the and the dvd it was programed to is broke, can you help it is about 7 years old. it says...
spacer.gifThe following steps will allow you to program your InteracTV controller:
  1. Make sure the InteracTV controller has good batteries. Slide the 3 position memory switch, on the back of the controller, to the desired memory position. The controller is capable of being setup for up to 3 different DVD players in 3 different locations.The controller must be setup and tested individually for each of the 3 DVD players, but once that is done the controller will retain the manufacturer's code and does not need to be setup again.If the consumer accidentally enters a new valid 4-digit manufacturer’s code, then they must set it up again for that DVD player.It is a good idea to write the 4-digit manufacturer’s code in the labeling area provided on the back of the controller.
  2. Insert the compilation DVD into the DVD player and turn on the DVD player and TV.
  3. Insert the programming card into the controller; the green light should blink twice.
  4. Locate the manufacturer’s codes in the user’s manual.
  5. Enter the first 4 digit code listed under the manufacturer. Use the right arrow button for the number. The light should blink after each button press and blink a long blink after the 4th digit is entered.
  6. Remove the programming card.The light should double blink when the card is removed
  7. Insert the test card into the unit;the green light should double blink.
  8. The DVD should skip to the test screen, if it does not, repeat from step 3, choosing the next manufacturer’s code on the list. If the test card skips to the footage, which resembles the test card, then proceed with testing the unit.See Testing the unit section of you manual or quick setup instructions.
  9. If you have tried all of the manufacturer's codes listed and you cannot locate an acceptable code, see programming the unit using manual search in your user's manual.
You also might want to check this site for full product support:
http://service.mattel.com/us/product_detail.asp?id=B9376&Ntt=B9376&Pn=1&Brand=Technical+Products&Cat=InteracTV
Hope it helped.
Nov 15, 2009 | Video Game Consoles & Games
Ws65909 Mitsubishi Tv and Dvd player
First forget the DVD.
  • Go into menu
  • and find close caption (TURN IT OFF)
  • If you find (TEXT) TURN IT OFF
those feature specially TEXT is who creates that square. was created for original programers to allow broadcasters send signals. Is not used for anyone. that squre is the empty space to write down a note. as i said not needed there TURN IT OFF. refer to your users manual to get easiest to this area. and read more about it.
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cannot program my tv remote to my dvd player
If you bought an Off brand DVD, the code my not be stored in the eprom of the remote.....Call Mitsubishi to be sure.
Jan 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
