Question about Acer AL1714 17" LCD Monitor
Volume Icon in Appears on the Screen
This volume icon appears on the screen and would not go away even after pressing the auto or menu buttons on the monitor.
When the menu option finally shows up, it seems to have a life on its own and will just run through the various icons. It would stop when the auto button is pressed but the volume icon shows up again after that.
Is there something wrong with the monitor and it's time to get a new one? OR is there something wrong with some other parts of the computer?
Thanks for helping
    New Friend:
  • 4 Answers
I had the same problem. Tilt the screen is pressing behind the buttons problem fixed.
Posted on Sep 18, 2015
  • 34 Answers
If you know how to open it its simple replace the switch botton on your monitor replace all
Posted on Nov 03, 2008
Nexus 7 won't turn on
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
May 19, 2014 | Google Nexus 7
Volume icon appears in the middle of my iPad 3 screen and won't stay off.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Apr 30, 2014 | Apple iPad 16 GB 3G Tablet PC
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
Gave my Pantech Element away how to change owner name
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Nov 02, 2013 | Pantech Element 4G LTE Android Tablet
My volume keeps on increasing even when i am not pressing the volume button.. and the icon appears on my screen after a while
you will need extra knowledge on iphone. you will need to open the iphone. extra technical knowledge and tools are necessary to open iphone. once opened, clean up the two button meant for volume.
Oct 08, 2013 | Apple iPhone Smartphone
Im locked out of my lg vortex android. how do i reset it.
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
  1. With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
  2. Release the Home key and Volume Down key when the Android icon appears.
  3. Follow the on-screen instructions.
Jun 07, 2011 | LG Cell Phones
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Installed AOC 2436vh, top of screen off of physical structure of screen, tried power down, physical reinstall, roll back of driver and reload of cd, how do I uninstall monitor to try again? Or adjust it...
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Dec 22, 2010 | AOC Monitor
Acer AL1714 17" LCD Monitor Logo
477 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
