2003 Ford Windstar Logo
Posted on Nov 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check engine light on and blinking
Van not running good shaking and burning oil low performance
Curt Downs
Level 3:
President:
  • Ford Master 1,779 Answers
  • Posted on Nov 03, 2008
Curt  Downs
Ford Master
Level 3:
President:
Answers
1779
Questions
5
Helped
976761
Points
6192
A flashing check engine light indicates a problem w/ emissions, this is why your car is not running correctly. Bring it to have trouble codes read--scanner is plugged into a port under the dash, codes stored in cars computer are read by scanner, results will indicate what is wrong w/ your van. Auto parts stores offer this service free, as well as advising u what to do. Have it checked out asap, continuing to drive it may result in more costly repairs. Let me know how u do.
Where is the oil sending unit on a 1996 mercury cougar xr7 ? Its cause my oil pressure gauge is bouncing up and down...i dont know why...can anybody please help me thank you so much
The low oil pressure warning lamp will illuminate anytime the ignition switch is turned to the ON position without the engine running. When the engine is running, the light also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
If the oil pressure light does not work, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp lights, make sure the oil pressure switch is properly grounded in the cylinder block, and if so replace the oil pressure switch. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
To diagnose an oil pressure light that stays on, perform the following:
  1. Check the engine oil level and top off as necessary. If the engine was 2 or more quarts low on oil, test start the engine after topping off the oil level and recheck the oil pressure light operation. If the light stays on, stop the engine immediately and go to the next step.
  2. Disconnect the wire at the sending unit, then turn the ignition switch to theON position. If the light remains on, check the wire from the sending unit to the gauge for being shorted to ground and repair as necessary. If the light goes out, turn the ignition switch OFF and go to the next step.
  3. Replace the oil pressure sending switch with a known good switch.
  4. Start the engine and check the oil pressure light operation. If the light stays on with the engine running, stop the engine immediately to avoid severe engine damage until the cause of the problem can be determined.
WARNING
If the oil pressure light remains on while the engine is started, stop the engine immediately. Do not operate the engine until the cause of the problem can be determined. Operating an engine with low oil pressure will cause severe internal damage.
Possible causes for an oil pressure light to stay on are:
Pinched or grounded sensor wireDefective oil pressure sending unitRestricted or severely leaking oil filterExcessive internal engine bearing clearance.Insufficient or severely contaminated engine oilBlocked oil pump pickup screen or severely worn oil pump
2008 Hilux 2.5 d4d, 2kd engine. Why does it belch blue smoke and shake a lot?
Blue smoke is indicative of burning oil, and the heavy shaking is showing that it's not firing properly on all cylinders. Check your oil levels and see if they have gotten low. Check your plugs and see if they are fouled or vaporized. It is likely you've got oil leaking into your cylinders, and that it is being burned during normal engine operation. If your plugs are fouled, replace them. If your plugs are fouled AND your oil is depleting, you're going to have to change out the gaskets in your engine, and I would also recommend you run fuel system / total engine cleaning and conditioning fluid (like SeaFoam) through your engine.
Check engine light blinking car shaking, oil light on after a few miles from starting
May be low oil, low oil pressure (faulty oil pump) or a bad pressure switch. When your at highway speeds the pump, pumps faster & brings the oil to the right PSI. Try a thicker oil than called for, get the oil pressure checked,oil leaks? & get the switch ckd out.
My check engine light started blinking andthe vehicle is shaking
a blinking ck engine light means you have a catalyst damaging misfire. the misfire is also the cause of the shaking and probably low power condition. you need to have the vehicle scanned asap and try to figure out which cylinder or cylinders are misfiring by the code read by the scanner. if you have a po300 code it means you have a random cylinder misfire. if you have a po301 through a po306 then go to the cylinder 1-6 designated by the last # in the code to figure the cause from there. look for a burnt plug wire, remove the proper sparkplug and ck it. also remember to change the engine oil as there is unburned fuel getting into it every minute this condition exists that the engine is running. good luck to you.
My van shakes when I come to a complete stop but
Check your transmission fluid... also check your engine oil frequently anyway... once a week at the least
Flahing service engine light soon and engine began shaking
Yep 20 seconds on a machine turning 650 rpms is low on oil wil destroy the bearings in the pistons and crankshaft. Mechanics refer to the red check engine light as the idot light, because by that time it's to late the car ran low on oil and damaged the engine.Try putting some SPT oil treatment in and see if it will fix it temporally otherwise you may be looking for a engine overhaul. If the yellow check engine light is flashings you may have burned the rings up on the pistons and it is now burning oil, or more oil causeing it to throw a code for the 02 sensor. Good luck
97 Ford Expedition with shkaing at idle and low speed
Most auto parts stores will scan the engine codes free or allow you to use theirs on site. Scan the code and post it back here for additional help.
5helpful
3answers
Engine shakes when Idling/ Check Engine Light started blinking
i just fixed a similar problem on my van there is a rubber elbow on the end of the pvc hose that connects to the valve cover you can only buy the elbow with the hose and it costs about 100 bucks but i guess they have had to replace a lot of these because the new one looks twice has strong you just have to check and see if its collapsed in on itself preventing air movement or leaking the shop will charge you 175 dollars to fix it plus the part but it only takes 20 minutes good luck
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
