Question about HP OfficeJet 4215 All-In-One InkJet Printer
HP officeJet 4215
I need to know how to set the phone ring for 2x to catch my incoming call on my fax. I have one land line and 2 phone numbers. I need the phone to ring 2 short rings to indicate that a fax is being received. I had thos OK before the hurrican IKE. The telephone company has done all they can do,, and they indicate it's my fax that needs to be programmed to receive incoming fax on the 2nd ring.
Puzzled CAP
    Scholar:
  • 78 Answers
Here is a link to the user guide.. This should provide info on how to program the fax to answer o n the second ring. I don't know however how you have 2 numbers assigned to one line?
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=351106&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Nov 21, 2008
  • comment
    comment Nov 21, 2008
    I am vaguely familiar with a device that would identify a fax from a voice call, but as I recall, these were optional third party items, and not built into the fax machine.
    The phone company use to offer an option / service referred to as "Distingtive Ring", which would allow the fax machine to identify a voice call from a fax call using a different ring, like the 2 short rings you referred to. However, there was still only one number and one line, not 2 numbers on one line.
    The third party device I am refering to above, would actually pick up the line, and wait to hear the fax tone, and then refer it to the fax, otherwise it would pass the call onto the phone.. I think HP offered something like this with their phone answering machine when it was used in combo with an all-in-one machine like yours. Maybe you just haven't hooked up the answering machine part?
  • gosaliyatejpal Feb 07, 2013
    9558956071
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do I recieve faxes?
make sure you are plugged into an analog phone line (not a multiline phone). second I would put a phone on that line and have someone call it to see if it rings through. Let me know what happens
Jun 22, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How to set machine to receive incoming fax?
Quoted from the manual: The HP all-in-one will not automatically answer calls. You must receive all faxes manually by pressing Start Fax Black or Start Fax Color. For information on receiving faxes manually, see Receive a fax manually. You might use this setting if the majority of calls on this phone line are voice calls and you rarely receive faxes.
This page has more information: http://www.fixya.com/support/p378554-hp_officejet_6210_all_in_one_inkjet/manual-3600/page-86
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 4215 all in one -how do I turn off the ringer
Taken from page 61 of here:
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
adjust the ring volume
The HP Officejet provides four levels for adjusting how loud it will ring when there
is an incoming fax or phone call. You can select Off, Low, Medium, or High. The
default setting is Medium.
1 Press Setup.
2 Press 3, then press 6.
This selects Basic Fax Setup and then selects the Ring Volume.
3 Press ! to select an option, and then press OK.
May 12, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I can send faxes, but cannot receive faxes.
Thank you for specifing your connection>
When you have a shared fax line it is import to have a Distinctive Ring Pattern which will differenciate the type of ring patter to recieve voice calls and Fax message.
All You need to do is get a distinctive ring pattern from your telephone service provider (AT&T) and setup your fax machine as per the ring pattern provided by your service provider.
All you need to do is set your rings to answer in youe phone to Rings 4 in your Phone.
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate basic fax setup> Press Ok and set the Ring Pattern to Number 5 or 6> Press Ok and cancell to come to the main menu
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate Advance Fax Setup> Locate Distinctive ring pattern and set it to the ring pattern which your Telephone service provider has alloted i.e Single Ring, Double Ring or or Triple Ring (Whichever is applicable)> Nd press Ok and cancell to come to the main menu.
Then you will be able to receive fax message voice cals and voicemail without any interuption.
Good Luck
Sep 25, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
May 20, 2008 | HP Officejet 4215v All-in-One Printer
NUMBER OF RINGS TO ANSWER FAX
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
change the number of rings.
4. Press OK to accept the setting.
May 14, 2008 | HP Officejet 4315v All-In-One InkJet...
How to fax
You would need to connect a phone line from the appropriate port on the all-in-one to an open phone jack in order to make faxing work. If that's a problem, you can use the scan feature and send docs by email as a workaround. If you want to get incoming fax service, though, you will need the phone line connected to the unit.
Aug 14, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
103 people viewed this question
Ben Johnson
