Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
Bunn VPS Black Three burner coffee Brewer
I have a older Bunn VPS coffee brewer I got off Ebay. All lights work, burners get hot, and I do fill the tank to the top. Its slow to start, but finnaly starts to heat the water for several minutes, then shuts off, never brewing any coffee. This goes over and over never a drop of water come out of the basket.
I did check the themostat, it is all the way up. I cleaned the hot water out let above the basket and checked for blockage. Dirty but clear.
Could it be that water is not geting hot enough?. Bad thermostat? Help!!
  • Alvin D. Easterday Nov 03, 2008
    Thank you, that dose make sense. Im used to the house hold type that pushes the hot water out automaticly. You are right, I"m missing the last step!
    Sergeant:
    Champion:
  • 347 Answers
Hello, check out this link, I think it is from the same problem you have.
Good luck, and let me know if it helped you,
Dahaka
Posted on Nov 03, 2008
    Guru:
  • 859 Answers
Once you have the reservoir full and its heated. You put coffee in the basket. Then to make a pot of coffee you add another pot of water from a carafe into the fill area. This causes an overflow of excess hot water from the reservoir to spray onto the grounds and make a pot of coffee.
If you had a plugged spray head, you would have overflow from the fill screen area.
Seems you just are missing a step. Tell me if I'm wrong, address your comments using my name first.
Thanks
Worldvet
Have a bunn vps series pour over that won't brew
VPS are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* You can test the VPR by following the Pre-fill instructions I've listed earlier. If the brewer heats up and does not continuously boil (shorted condition) then try a brew. If it works then your okay. Otherwise the unit will need service for a blown high limit or bad heater element.
* Call your coffee vendor anyway. Many coffee vendors will service your brewer of even replace it as long as you buy coffee from them. Ask around.
Aloha, ukeboy57
May 27, 2017 | Bunn Coffee Makers & Espresso Machines
BUNN VPR NO HEATED WATER
You should call your vendor for service. Especially if it's on loan from them.
*** The following is for information only. Equipment should be serviced by a qualified tech. ***
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater powers up. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* FYI Coffee grounds are usually in pre-messured packets for office use. A simple guide is one tablespoon per cup. (level or heaping spoon is up to you)
* Since your brewer was bubbling at one point. I'm guessing it had water in the pre-heater at one time. But if it's not in use and left plugged in all that time then the water has probably boiled off. Hopefully someone unplugged the brewer prior to the unit blowing the thermal fuse.
* check bunn.com for free download of VPR manual
Aloha, ukeboy57
Jan 06, 2014 | Bunn VPR Coffee Maker
I just get bunn VPS it is and work very good
The switches are for the "warmers" only. The brewer has a reservoir the keeps water hot and ready for brewing. When it is not re-heating water (after brewing) it has a "keep warm" heater that is low voltage and keeps it ready to go.
May 16, 2010 | Bunn VPS Coffee Maker
Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
Nov 11, 2009 | Bunn VPS Coffee Maker
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bummer Bun
The pour-over type of Bunn coffee brewers require several pots of water to fill an empty tank.
1. While unplugged, pour in two and a half to three pots of clean water (put an empty pot underneath the brew basket). When the tank is full, water will come out of the brew basket.
2. Plug the unit in and wait for it to heat - about 5 to 7 minutes. These brewers are meant to be left plugged in all of the time to keep the tank water hot. You will probably heat some rumbling noises which is normal as the water heats.
If for some reason the water isn't hot after 10 minutes you will need to check the thermostat. Unplug the machine and take the screws out of the top. The thermostat has a little dial or a t-bar that you can turn. All the way left is off and all the way right is boiling. Turn this up about 90% of the way and put the top back on the machine and plug it in. If it gets hot, you are ready to brew. If it doesn't get hot, you may have blown the limit thermostat and will need to replace it.
The limit thermostat isn't the same as the thermostat. It is a ceramic and metal item that senses if the tank gets too hot from having the unit plugged in without any or enough water in it. It is inexpensive and relatively simple to change.
Nov 25, 2007 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Coffee Brewer comes out warm not hot
look at the top of the coffee maker you'll see two screws and the warmer tray and the cover for adding water. remove the two screws and lift the top off. the warmer has two push on spade terminals. pull the wires off them. below is a tray where the water goes and you'll see a brass bushing. this is screwed into a fitting on the water tank. use a piece of steel as a spanner and unscrew this fitting. don't lose the gasket that's under it. the main wires for the burner element and thermostat are also under this tray. look at the top. there's nine screws that hold the top on the water tank. two white wires go to the tank warmer and two wires go to the tank heater inside. you can try turning up the thermostat setting to a higher range and see what happens. there's a copper pipe that comes from the tank to the sprayhead the tank holds approx three urn fulls of water. if you have an analog meter you can check the element for continuity on the RX1 range. Do the same with the tank warmer element. Bunn-o-matic has a web site you can buy replacement parts or nelson appliance can get you parts too.
Nov 19, 2007 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
99 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
