Question about IBM (02R4084) Motherboard
IBM NetVisat 02R4084 Mainboard
Hello All, I have an 02R4084 mainboard from a Netvista. The front panel connector is single plug 8-pin in-line. As I am about to fit this board into a non-IBM computer that has the conventional seperate connections I need to know which specific pins are SW power, Reset, HD LED, Power LED. Can somneone advise me please as I cant find anything on this in any publication ? Thanks. Incidentally does anyone know who makes this board for IBM ?
  • ronjito Jul 08, 2008
    Hi!
    I have the same problem as BenLogan have. The front panel 8 pin connector were not labeled and my computer case is not an IBM and my 3 separate connector were labeled but to plug it to the right pins are the problems. I need help to locate SW, HDD led, etc.corresponding pins.
    Thanks
    Ronjito
  • crash101 Mar 08, 2009
    Where can I get the manual for 02R4084 IBM Motherboard
    Scholar:
  • 161 Answers
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Posted on Aug 12, 2007
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with IntelĀ® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
I replace my power supply for my E520 and its dose not turn on. It is a new replacement power supply for this model. I check alll the connections. It haas aa blinking amber light all time.
I would double check the connections to the main board. Some power supplies have two power connectors to the mother board, a 20 pin connector and a 4 pin connector. Sometimes the four pin connector is in a different location from the 20 pin on the board. Make sure both connectors a plugged in.
Make sure the connector for the power switch is plugged into the board. Dell's usually have all the wires for the front pane in one connector.
You should also unplug everything from the board except the power supply and front panel. There could be a hard device causing the board to hang up.
I have had power supplies die and short the main board. I hope that isn't the case here.
Jul 02, 2011 | Dell DimensionTM E520 PC Desktop
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
The extra pin in Netvista/thinkcenter front panel USB
Thank you, you are most kind.
I would wish that you would take a moment, and join FixYa. It is free to join, and we'd love to have you on board.
Regards, joecoolvette
Dec 22, 2009 | IBM NetVista PC Desktop
I need to replace a part and cannot read the part number
Hi res0m9hv,
HERE's the maintenace manual that lists all the p/n on the board.
Good Luck
Mark
Nov 20, 2009 | IBM Computers & Internet
Ibm netvista x41 wont power up
measuring 12v at the psu is not enough. the psu have several voltage outputs ranging from 12volts to 3.3 volts and maybe even 2.2 volts.. firstly, check all onboard USB ports, a bent or shorted pin in a USB port will prevent the psu from operating. next, the psu has a safety connection to the mainboard, this is called the power good signal ( pwrgd) and it is a signal from the psu to the mainboard and tells the mainboard that everything in the psu is functioning correctly. If the powergood signal is lost ( drops from 5volts to zero volts) the mainboard will issue an interuppt to the cpu and the cpu will shut down, this will also shut the board down to prevent damage and data loss. mainboards all use pretty much the same connectors so your board will have either a 20 pin power connector or a 24 pin one. It may also have an additional 4 pin connector to power the cpu and northbridge functions. use a known good psu and plug this into your board along with the 4 pin connector and attempt a switch on. If the system begins to boot, replace the psu. if not, try unplugging or removing everything connected to the board, pay special attention to expansion cards and usb ports. remove the ram sticks and video cards if fitted, then attempt to boot again. if the system does not respond, replace the main board. if it now begins to boot, refit everything one item at a time and try starting the machine. turn off before refitting the next item and start the machine up again. when you get to the problem item, the machine will stop starting. If all else fails, replace the mainboard or take the machine to a reputable repairer..
Oct 30, 2009 | IBM NetVista X41 PC Desktop
Acer m464 front panel connectors
Sorry in the 1st instance for my lack of specific knowledge when it comes to ACER hardware.
Is the model of your MOTHERBOARD - Acer m464?
If so do you happen to still have a manual that came with the motherboard?
Sometimes you can see the pinout in white writing on the mainboard itself near the connector block... have a close look and see if it is there.
The pin out for the connector block will definately be in the mainboard manual. If you don't have the manual then you'll need to do a little searching for it... I'm sure a .pdf of it will be floating around... i guess start at the ACER site.
On the rack mount chassis, are the plastic chassis connectors grouped (ie. 2 wires into 1 connecter for pwr led, etc) or are they individual single pin connectors?
Either way for each group, one should have a little TRIANGLE on the opposing side to the writing. Conventionally this is your positive (+) pin when looking at the pinout diagram. Ensure you have correct polarity for all ur connections obviously.
See how you go mate.
Mar 25, 2009 | Acer Computers & Internet
Motherboard
Part / Feature Specification / Support Motherboard description
  • Motherboard manufacturer's name: MSI MS-7174
  • HP/Compaq name: Graphite-GL8E
CPU/Processor
  • Socket: 775
  • Supports the following processors
    • Pentium 4 600 series
    • Pentium 4 with HT
    • Celeron D
Front-side bus (FSB)
  • 800 MHz (Pentiums)
  • 533 MHz (Celeron D)
Chipset
  • Northbridge: i915GV
  • Southbridge: ICH6
BIOS features
  • The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral devices and expansion cards of the board automatically.
  • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Form factor
  • Micro-ATX form factor: 9.6 in x 9.6 in
Memory
  • Dual-channel memory architecture
  • 2 x 240-pin DDR2 DIMM sockets for up to 2 GB non-ECC DDR2 533/400 SDRAM
  • Maximum HP/Compaq approved memory is 2 GB
Expansion slots
  • Three PCI
Video graphics
  • Integrated
Serial ATA
  • 2 SATA connectors
  • Each connector supports 1 serial ATA-150 disk drive
Onboard audio or audio card Integrated Intel High Definition(TM) audio (Azalia)
  • Realtek ALC 880 CODEC
  • THX certification support
  • 8-channels for Full Dolby 5.1/6.1/7.1 surround sound support with Dolby Pro Logic IIx
Onboard LAN
  • Intel 82562GT
  • 10/100Mbps Fast Ethernet LAN controller
Back panel I/O
  • One PS/2 mouse port
  • One PS/2 keyboard port
  • One VGA (monitor)
  • One Parallel
  • Four USB (2.0)
  • One IEEE 1394a
  • One RJ-45 networking port
  • Six audio ports support 8-channel Azalia audio codec
  • One S-video out
  • One SPDIF in/out
Internal connectors
  • One 24-pin ATX power connector
  • One 4-pin 12V ATX power connector
  • One IDE connector
  • Two SATA connectors
  • One floppy drive connector
  • CPU fan connector
  • PC fan connector (also known as duct or chassis fan)
  • PC indicator LEDs / power switch / reset button connector
  • Optical drive audio input
  • Auxilliary audio input (may be used for line input)
  • Front panel headphone and microphone connector
  • Two USB headers supporting up to 4 additional ports or devices
  • One IEEE 1394a header supporting one 1394a port
Jul 27, 2008 | Compaq Computers & Internet
Jumper settings on 8307-48U mainboard
Have you loked at this page, apologies if no good, but there is a setup manual http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42970
Feb 12, 2007 | IBM NetVista M42 PC Desktop
Computers & Internet Logo
2,325 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
