Question about Kenmore Elite 45986 Front Load Washer
Water in Barrel
My kenmore washer is filling up with water when its not in use. Any suggestions? Thanks, Cynthia
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a bad water inlet valve stuck open and permitting water to enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Posted on Nov 03, 2008
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Barrel fills up but does not empty
Barrel -ok, your tub is full of water, check the lid switch. If it is not the problem you will have to give more information........To get at the lid switch you have to rotate the control panel up, it is either fastened with screws in the back side of the end caps or you push in to release some spring at the base of the end caps of the panel. Usually there are three wires to a lid switch, the center is the ground with the outside two being hot and neutral.
Jan 14, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer fills with water
You may have a bad lid switch. Need the model to check for you. Thanks
Dec 01, 2009 | Kenmore Washing Machines
Washer filled with water but never began cycle
It sounds like the controller/timer unit has failed and needs to be replaced. I hope that this help you resolve the issue. Please rate this response. Thanks!
Aug 24, 2009 | Washing Machines
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer won't stop filling w/ water
The problem is most likely the water level switch. This would be the case if the water is able to be turned off with the dial on the washer and not running all the time.
If it is running all the time and you have to turn it off at the water line valve, then the problem is a stuck water fill valve.
If you need more help, post a comment.
You can find information on the parts at partselect.com.
You can buy parts from them or find them locally if you want.
Thanks,
Tim
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Cold water fill cycles very slowly on and off during fill
Replace the cold inlet valve, it is obviousl faulty, unless of course it has a filter, if so, then remove and clean.
Plz rate my solution
Thanks.
Jan 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
123 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
