Question about Mitsubishi WS-55809 55" Rear Projection Television
WS-55809 TV Won't Come On W/Fault Code 22
Hello, from reading your previous post I have solved and repaired faulty solder contacts in my TV. That was about 6-7 months ago. It worked fine until today when I turned it on and it promptly clicked and shut down. From reading posts and solutions, I figured out how to retrieve the fault codes. It was 22. Reading further I saw where it was told to check fuses F9A04, F9A05. I unsoldered F9A04 and tried to check it. I have "No continuity" one way. The other way I have some continuity. Is this type of fuse different then a normal fuse? or am checking it wrong. I didn't want to unsolder the other fuse if i didn't have to. Furthermore I would like to order a repair manual & parts if I can diagnose the problem. Any help would be wonderful. Thanks
    Problem Solver:
  • 31 Answers
Replace the fuses again and the IC8c01 and IC8C02 all together
Posted on Dec 02, 2008
I have a projection television ws 55809 it turn off everytime i try to turn it on i did the test an 22 was the code what is it and how do i fix it
What you have is short protection--it means one of two pico fuses on the middle board is bad and it and the two STK-392-570 chips it uses for convergence are going to have to be replaced and the set adjusted with the Mitsubishi remote.
This can be a do it yourself repair for some people with basic skills and parts cost from a site I know will be under 30 dollars.
In addition I have my own start to finish, step by step instructions for this which are available if you provide a email address.
They tell you everything you will need and precisely how to do the repair. Once you have and read them you can decide if you can do the repair or not--shops usually get over 200 dollars parts and labor for this repair.
I attach a photo of the fuses (on middle board) and what the chips look like (also on middle board at the front)
12_18_2012_12_41_53_am.jpglike this but will have the 570 number on them.
Dec 17, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 5511 getting a code 22 - short protection fault. How
Code 22 points towards a failure in the convergence section of the TV. You can get a convergence repair kit from www.TvRepairKits.com to do the repair yourself.
Apr 20, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Color changing while viewing
Sounds like your TV needs new convergence chips.
Go to this web site.
http://www.tvrepairkits.com/xcart/home.php?cat=2653
If you can handle a soldering iron and solder fairly well, then you can do the repair.
Hope this helps.
Apr 03, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red convergence on my ws-55809 is off
The lense adjustment won't help. There are two convergience chips inside, each has 16 pins. If you take the big tray, with all the boards, out and turn it over, you will see that one of the chips has a pin that goes to a contact labeled, "RH." You can't miss the chips, they are stuck to a huge, finned heat sink, about 4'' x 7". Check the continuity from that pin to it's contact with an ohm meter. You may get lucky and get by with simply a re-solder or jump on that pin. Those convergience chips are like computer processors, are subject to extreme heat, depend very heavily on their heat sinks and cooling fins and could easily get hot enough to break a solder connection. Like computer processors, they should have been designed with fans as well as heat sinks. Don't kill yourself. Even unplugged, a tv has enough stored energy to be fatal.
Mar 08, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red and green ghost images on screen. usually appears after tv is warmed up. TV is 8 years old. Is it worth repairing? How much to repair? I have read that it may be problems with convergence chips.
Since the problem comes on with the set warmed up the most likly cause is cold solder joints. This happens because componets heat up and cool down at differant rates and over time cause the solder conectin to break or become intermitant. The simple fix would to get the convergance IC's soldered and while in there solder up the entire high voltage section
Dec 18, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 installing STK392-570
un solder ics replace both of them resolder make sure you do not solder any of the circuits together or it will short something out,also ck low ohm resistors in same circuit.I will try to help you the best that i can. Main key you must know how to Solder.
Dec 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws 55809
22 is short protect usually its the convergence Ics in that model that can short out. check fuses F9A04 and F9A05 if they are open its most likely the convergence ICs that need repslacing. If you need further assistance, please reply to this same post.
Jul 29, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Green Gun does not come on
my tv comes on but it says your input is locked enter your 10 diget code press enter but i dont no it
Jul 16, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
