Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Weather Maker 8000 wont start with error code 21
I have a Carrier Weather Maker 8000 that has refused to start this winter. On checking the error codes comes out to be 21 which states gas blockage. One of the suggestion was to shut off the heater and let it reset which has not helped. (Left it Off for the whole night but when started the next morning, it still did not start. The ignitor comes on but since gas fails to come, it glows for few seconds and then turns off. Any suggestion would be appreciated.
  • 1 more comment
  • Geevan Nov 04, 2008
    I checked again today and from what I can gather, the error code is 12 and not 21. The error code 12 translates to "blower on after power up" or "R-W Closed". I have no idea what all this means. Any help would be appreciated.
    Thanks
  • rlambl Dec 18, 2008
    what is a code 12 on carrier weather maker 8000 and how can i fix it
  • Frogger9602 Mar 30, 2009
    I have the same problem, code 12, AND my furnace is amking an awful loud clumking noise.
2 Suggested Answers
boanhtgclg
  • 34 Answers
SOURCE: Gas not coming on Carrier Weather Maker 8000
either the gas valve is not opening or your not getting gas to the furnace.  also the gas valve won't open unless the draft motor comes on.  if the ignitor is trying to light, but there's no gas, it might be a bad gas valve. i would call your closest NATE certified contractor
Posted on Nov 17, 2008
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Hi, I have no power coming to the weather maker...
double check the breakers. Turn ALL THE WAY OFF, then ON.
Oct 22, 2017 | Carrier XHB123D X/Y Series Heat/Cool Air...
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Nov 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Caerrier weather maker 8000
Your cooling coil may be frozen. Turn the fan on and the cooling to off so air will circulate to defrost the coil. After air circulation is re-established in about 90 minutes turn the cooling back on. Operate the system with the fan on when in the cooling mode should eliminate the freezing problem.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ignition failure
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,302 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
