Question about Microsoft Windows XP Professional
New application software can not installed
I get following error message. " The windows installer service couldnt be accessed. This can occur if yor are  running in safe mode. or if the windows installer is not correctly installed. pls guide me
    Novelist:
  • 208 Answers
I SOLVED THIS ON MY LAPTOP BY REINSTALLING THE WINDOWS INSTALLER. THIS PROBLEM USUALLY HAPPENS WHEN THE INSTALLER IS CORRUPTED BY SOME MALFUNCTION. THE BEST SOLUTION IS TO UNINSTALL AND RE-INSTALL THE PROGRAM FROM THE MICROSOFT WEBSITE. HOPE THIS HELPS YOU.
ARCLIGHT1217
Posted on Nov 05, 2008
An error message occures"The Windows
Hello and Welcome to FixYa!
Try This;
  • Click Start, click Run, type MSIEXEC /UNREGISTER, and then click OK. You won't see anything when you run this command.
  • Click Start, click Run, type MSIEXEC /REGSERVER, and then click OK. You won't see anything when you run this command. On some machines you may briefly see an hourglass. After this, the operation is complete.
  • Try installing the application again.
I Hope this will solve your issue.
In Case, do tell me.
Concerned, Nooh: Team FixYa!
Aug 04, 2011 | Computers & Internet
Icannot get rid of the folliowing: Error 1706 Win DVD.
hi there,
May you provide the complete details of your player like the maker model..
`jack
May 23, 2008 | HP Televison & Video
This message appeared " driver_irql_not_less_or_equal" TECHNICAL
Hello !
This system-halt message occurs when a process (in kernel-mode and not user mode) or driver tried to access a memory address to which it did not have permission. The most common cause is an incorrect or corrupted pointer that references an incorrect address in the memory.
When this occurs in a user-mode application, it generates an access violation. When it occurs in kernel mode, it generates a STOP 0x0000000A message. If you encounter this error while upgrading to a newer version of Windows, it might be caused by a device driver, a system service, a virus scanner, or a backup tool that is incompatible with the new version.
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. Choose the "Last Known Good Configuration" option. This option is most effective when only one driver or service is added at a time.
Usually, from my experience this rarely happens, but it is a buggy DRIVER installed by you.
Get back with more details please if it still happens. (Tip : Try to re-install all drivers using the manufacturer's website).
Aug 02, 2011 | Microsoft Windows XP Professional
Hi I bought the game blitzkrieg 2 and installed it to my computer but when i hit the play button there's in error sign that reads as follow Internal error when accessing one of the applications libraries...
maybe there is something error occured when the installation take place. Make sure that the application is safe from virus and scan it. Then, re-install it for better action. Hope I help.
May 12, 2010 | CDV Software Blitzkrieg for Windows
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
Application failed initialise properly (0xc0150002)
I am quoting from Microsoft website for your convenience:
SYMPTOMSWhen you start an Office 2003 program on a Microsoft Windows XP Professional-bas... loadTOCNode(1, 'symptoms'); When you start an Office 2003 program on a Microsoft Windows XP Professional-based computer, you may receive the following error message: The application failed to initialize properly (0xc0150002). Click on OK to terminate the application. CAUSEThis behavior may occur if you install Office 2003 and Windows XP Service Pack 1... loadTOCNode(1, 'cause'); This behavior may occur if you install Office 2003 and Windows XP Service Pack 1a (SP1a) on your computer, and do any of the following:
  • You upgrade your Windows XP Home-based computer to Windows XP Professional.
  • You reinstall Windows XP on your computer.
  • You perform a repair of Windows XP on your computer.
In this scenario, when you start an Office 2003 program, you may receive the error message that is described in the "Symptoms" section. RESOLUTIONTo resolve this behavior, after you upgrade your Windows XP Home-based computer... loadTOCNode(1, 'resolution'); To resolve this behavior, after you upgrade your Windows XP Home-based computer to Windows XP Professional, or you perform a reinstall or repair of Windows XP, reinstall Windows XP SP1a on your computer.
After you reinstall the service pack, restart your computer. MORE INFORMATIONFor additional information about how to obtain the latest Windows XP Service Pa... loadTOCNode(1, 'moreinformation'); For additional information about how to obtain the latest Windows XP Service Pack, click the following article number to view the article in the Microsoft Knowledge Base: 322389 (http://support.microsoft.com/kb/322389/EN-US/ ) How to Obtain the Latest Windows XP Service Pack
For additional information about how to install Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 316941 (http://support.microsoft.com/kb/316941/EN-US/ ) HOW TO: Install Windows XP
For additional information about how to reinstall or repair Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 315341 (http://support.microsoft.com/kb/315341/EN-US/ ) How to Perform an In-Place Upgrade (Reinstallation) of Windows XP"
Aug 17, 2009 | Microsoft Office Professional 2007 Full...
AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = http://housecall.trendmicro.com or
Panda http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
Feb 03, 2009 | Microsoft Windows XP Home Edition
I have tried to down load some updates to my programs and I get the following message: The windows installer service could not be accessed. This can occur if you are running int he samve mode, or if the...
Is you windows at automatic update enable, Ok try this on the RUN dialog box type SERVICES.MSC and press enter and see your automatic update should be AUTOMATIC under the start up type. Doubleclick on automatic update to do changes to the settings and see what happens. cheers
Nov 14, 2008 | Gateway Computers & Internet
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
