Question about Panasonic SC-HT900 System
DVD player stops frequently during playback
My DVD player keeps stopping during playback of movies and reverting back to blue setup screen. I use only commercially bought DVD's and I can see no scratches or grease marks on the DVD's, nor do they appear to be warped. Is the laser dirty? Is it time to service - or can I fix this?
    President:
  • 3,130 Answers
Yes first try to clean the laser with a lens cleaner. If that does not work you can then try to take off the cover and clean off the lens manually with a slightly damp cotton swab and alcohol. After that turn around the swab and dry the lens with the dry side of the swab. If that doesnt work then it Probably is out of alighnment or the spindle motor is bad, and is most likly not worth the bench charge for an estimate.
Posted on Sep 27, 2006
SOURCE:
My Blu ray player randomly stops playing movies but all other setting work
Have you made sure the disks are clean and have no marring on them? Blue Ray players are very sensitive to any disk issues. Also have you checked to see if any updated Firmware (the software the system uses to read the movies) has been released for the player? They constantly update the operating software of players and the way the disks are recorded, so regular updating is essential to prevent this type of problem in playback, freeze up is the most common complaint.
Feb 07, 2012 | Televison & Video
Avatar menu keeps poping up while the movie is playing
Make sure that the blu ray player is indicating that the latest firmware is installed on it. Press the setup button go to settings and down to version. Then record the version number. If it is the most current firmware version number after all call 800-237-4277 pressing 1 for all of the prompts. Inform the representative that with the firmware version number installed on your bluray player you are having this problem with Avatar. This helps because Sharp is
gathering information on any occurrences after an update and they are working on another update to resolve any occurrences
May 10, 2010 | Sharp AQUOS Blu-ray Disc Player
Jensen player
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
Apr 06, 2009 | Jensen VM9410 Car DVD Player
Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Dec 29, 2008 | Yamaha RX-V1700 Receiver
Onscreen angle icon cannot be disabled during layback of disc
After many long minutes of searching, I found the solution:
Depending upon your model of Pioneer player, you can switch this off in the Setup menus. Look for an entry about "Angle Indicator".
This worked for me. I had to stop the movie, go into the 'home menu' on my remote. Now I'm back to enoying Spirited Away without the annoying camera angle and blue line.
Feb 13, 2008 | Televison & Video
Obscure logo appearing on screen during playback
Turn off angle marker in the settings
Jan 08, 2008 | Televison & Video
DVD Freezes during playback
it might be that you are playing a dual layer dvd in the player. The player needs to focus on the second layer of the movie, and that might be why the dvd freezes. Leave it there for a while and the dvd should continue if it is this situation.
Dec 08, 2007 | Sony AVD-C70ES DVD Player
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Dvd movie playback
Techies may be right- the only way to find out is to get a cool breeze around the unit- a fan say- whilst in operation.
Jun 07, 2007 | Panasonic SC-HT720 System
Panasonic SC-HT900 System Logo
287 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
