Question about Jensen JER-422 Universal Remote Control
Residential roofing code - Denver, CO
I need to redo the roof over my patio. The patio was an addition to the house. It is attached. It has rolled shingle on it right now, but I have heard that this is no longer up to code. I am in Adams County, Denver, CO. Does anybody know the answer?
2 Suggested Answers
  • 10865 Answers
SOURCE: Roof Decking for Galveston County Texas
http://www.informationdestination.cengage.com/ReferenceContent/Roofing/Plywood%20Roof%20Decking.pdf
If you have a plywood roof deck, make sure that you have at least 15/32" (or ½") plywood thickness if the rafters are set at sixteen inches (16") on center. If your rafters are twenty-four inches (24") on center, it is recommended that your plywood is at least 5/8" inches thick. All plywood should be Exposure 1 Rated plywood and be rated for structural use by the APA-The Engineered Wood Association. This is indicated by a stamp on the plywood that states "32/16" rated. What this means is that particular board is rated for sub-flooring where the floor joists are 16" on center and for roof decking where the rafter or roof joists are 32" on center. The APA recommends a 1/8" gap be left between adjacent panels of plywood/OSB.
please rate this answer as a FIXYA! thanks
Posted on Mar 05, 2009
What Kind Of Roof Is Ideal For My Property At Kansas City?
A.metal [higher cost, longer lasting] if surrounded by trees that encourages mold growth on shaded roofs. one common material is steel pieces about 2x4 foot having a shingle design.
B.individual fiberglass shingles if roof is in clear sunny area.common size is about 1x3 foot having shingle design. ensure adequate, screened in venting, under eves and out venting high on all roofs.
obtain multiple quotations from reliable roofing installers as they have experience, insurance and proper equipment.
ask neighbours with newer roofs for opinions.
Mar 03, 2018 | Miscellaneous
Leaking roof
You need to call a roofer to install some metal flashing pieces. That will create a metal channel for the water to flow down instead of through your roof. Look in the Yellow Pages of your local phone book.
Dec 30, 2013 | Computers & Internet
House repair
The general price is $4.50 a square foot
Apr 18, 2013 | Kitchen Ranges
How to install slate roofing
A slate roofing is actually a nice idea because its make your home quite pretty. To use slate roofing first you need better kins of slates its breakable also but now including roofing you should try another options like metal roofing, rolled roofing , its easy then slate roofing you can also visit http://andersonindustrialroofing.net/replacement/
Jan 12, 2013 | Roofing
Sunglo panels on roof leaking with hole how do i patch them
stuff with foam that grows then use roof sealant or RV roof self leveling sealant
Nov 20, 2017 | Sunglo Black Portable Liquid Propane Gas...
Wet ceilings
You must conact your roofer and complain... COMPLAIN.. it sounds like you have a leak and the installers have allowed moistere to get under the roofing materials...!!!
Basically water expands when it freezes (ice cube tray.. over filled ) so if there's any kind of leak the water penetrates.. feezes allowing it to migrate up under the materials and then as the warm air from inside the attic causes the ice to then melt. I'd call and find out what the deal is.. especially if this has been going on SINCE the new roof was installed....
good luck
Oct 26, 2008 | Measuring Tools & Sensors
Collecting water on top of house boat from air conditioner
Thess units are designed to discharge the condensed water onto the roof under normal conditions. HOWEVER you should be able to have a sheet metal person make up a drain pan to fit under the unit.
You would ten need to add an additional gasket between the drain pan to roof and drain pan to A/C unit. The drain pan could have a hose connection attached to the drain pan. Try it, you might like it.
Also you may have to get longer screws to tighten down the A/C from below.
Jul 22, 2008 | Dometic Rooftop RV Air Conditioner
Televison & Video Logo
928 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
