I just got this and am trying to istall the driver cd and when i get to the part where it tells me to connect the printer cable to the USB port, i do and it keeps saying it is not found. I tested the cable to my other printer and it worked fine. Please Help. Thanks
    Problem Solver:
  • 15 Answers
This might sound funny but make sure the printer is turned on when pluging it in.
You can also try a different port also! If you are using USB Cables
Let me know if that doesn't do it
RJ
Posted on Nov 03, 2008
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
CHARCOIS
Oct 17, 2008 | HP Office Equipment & Supplies
Hello, I have a SATO CL408e, with a parallel connection. I have used a parallel to usb to connect to my laptop and i have istalled all the drivers. I have the port set to LPT2. The problem is the device...
In the past I have got that problem several times. The truth, it will always be better to use technology from this century. ;)
The problem with adapters is that they are usually chinese and those drivers are horrible. I usually solve it by buying the most expensive adaptor on the store, which usually includes a Driver CD. The OS could be helping to make it even more difficult. If you have a Windows Vista, you will not have an easy time printing.
Apr 05, 2012 | SATO CL408e Thermal Printer
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
I would like to print off of my lap top HP paodion dv7-1451nr Where is the port for the USB cable ? Is there a program/Cd I need for this?
Printers do not have a standard USB port. Instead, they use a port that is a bit more square. The cable you'll need is USB one one side and Printer on the other wide. These are extremely easy to find at an electronics retailer and are commonly known as a printer cable.
Whether or not you'll need a program/CD depends on your computer. After you have the correct cable, you can try connecting the printer to your laptop and seeing if the driver already exists/works correctly. If no luck, you can use the Internet to go to Canon's website and download the correct driver for your printer. That should get things going with no Program/CD needed.
Mar 01, 2011 | Canon MP560 All-In-One InkJet Printer
I have just bought an epson stylus sx125 and am having problems installing it. Can you tell me the driver port. I have thge software disc.
The specs says it is a usb device. driver port does not mean much to me. You need to load the drivers using the cd first then connect the printer when instructed by the install program or when the driver software installation is complete. you need a Usb cable.
Dec 20, 2010 | Office Equipment & Supplies
I have Win. 7 and have tried to use my pixma ip3000 with it. According to my pc, I have successfully installed the Win. 7 drivers for this printer. Yet when I try to print a document, I get a message...
remove usb cable, remove driver and restart your pc. after booting re connect printer usb cable from there found new hardware must be appear and then load your driver manually. if no new hardware found replace usb cable, or maybe the problem is in printer itself.
Mar 30, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
Nov 19, 2009 | Sharp AR-507 Copier
Usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
My printer doesnt workproperly
I'm assuming you're getting a communication error. This can be caused by a electronic fault in the printer or corrupted printer drivers or corrupted USB ports. To eleimate the ports and drivers do this. Donwload and run Dr. Web, Malware Bytes and Superantispyware. That'll take care of any nusciences. Now goto Start, Run and type SFC /scannow. Be prepared to insert your operating system disk. This will insure we have good USB ports. Now go to Start, Control Panel, Printers and Faxes. Make sure your printer is listed as the default. If not use Find printer and be prpared to insert your printer's CD. Once we have good drivers and good USB ports, then the only thing left that can cause a communication error is the cable or the printer. Good Luck
Apr 04, 2009 | Dell V305w All-In-One R840635AU InkJet...
jasbo
jasbo
