Question about LaCie Big Disk 500 GB Hard Drive
When I plug in my external harddrive, Windows misidentifies it. It wasn't always this way...?
OK, I bought a Lacie Big Disk 500GB hard drive it works fine once windows properly identifies it. However presently, no matter what sequence I turn it on or plug it into my usb port Windows tries to install it as new hardware instead of just accessing the files or offering me the choice window. I'm deffinately no techy and I think this is an easy solution but my friend whom is sent his hard drive back to manufacture for repair for the same problem. That's not right is it? Anywho, thanks Scott
  • LaCie Master
  • 2,075 Answers
If Windows system did any upgrades it could lose drive settings. First, allow it some time to rebuild driver's database; if that doesn't work then try to restore windows to previous point.
Posted on Jun 02, 2017
SOURCE:
headstrong
  • 233 Answers
SOURCE: Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Posted on Jan 09, 2008
Geekman
  • 32281 Answers
SOURCE: Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: My 500GB Lacie harddrive says it full too
Way too little information to solve this problem. Operating system and connection type are good places to start. errors if any during installation, startup, or during connection also would help. format type and OS format type and if it was previously used on a different type of system like mac to pc or linux/unix.
Posted on Jun 19, 2009
ryancsmith
  • 62 Answers
SOURCE: Hi I have a Lacie External Harddrive 500gb, when I
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Posted on Nov 30, 2009
yammy_alf
  • 666 Answers
SOURCE: windows 7 won't recognize lacie 500 gb hard drive
let it windows 7 format your lacie 500. and check for permission.
Posted on May 02, 2010
I bought today a lacie hard disk 500GB and instead of 500GB has only 9.99 MB space.What's the problem?
Sounds like your have a 9.99mb partition on your drive with the rest being free space.
If you are running windows goto the Computer Management program and check under storage> disk management to see if your 500gb drive is there. if it is delete the existing partitions and reformat the entire disk to NTFS
May 21, 2011 | LaCie Big Disk 500 GB Hard Drive
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External Harddrive Overheated
The disk in side is jammed, try throwing the harddrive like a frizbe but dont let go. That might help unsick the drive
Mar 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Big Disk 500 GB Hard Drive Logo
63 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
