Question about Panasonic CT-32SC13 32" TV
Tv wont turn on
Tv  was on  working fine switched it off  then 4 hours later tried to turn it on and nothing happened  why is this
I went to turn on my TV Friday night and it would not turn on. There usually is a red light that is on when the TV is off and that light turns green when the TV is on. That light is not red, green, or anything. It simply isn't on. The TV will not respond with either the remote or just using the buttons on the front of the TV. I've tried unplugging it and plugging it back in, changing outlets, and leaving it unplugged for 12 hours or more and it still will not work. What is wrong? Help me, please!!!
TV WONT POWER ON
LOOKED FOR A FUSE CLOSE TO POWER CORD UNABLE TO LOCATE. MODEL PANASONICCT-36SC13G Using the remote control attempted to power on 32" Panasonic TV (about 4 yr. old). When I pressed "ON" with remote, TV attempted to come on, then red light on TV controls when dark. Now TV will not power on at all, either manually or with remote. I think when I pressed "ON" I may have pressed one or more of the component buttons simultaneously as they are near the On-Off button on remote. When I did that, the TV screen attempted to light up, then went dark. Since then, nothing. Cannot even manually power on.
  • 101 Answers
Unplug the unit and leave over night. replug the TV in. in the morning to a known good outlet. if this don't work take it to a service center.
Posted on Dec 18, 2010
    Sergeant:
    Champion:
  • 318 Answers
Take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Posted on Mar 26, 2009
2 Suggested Answers
SOURCE: tv wont turn on
I had the same problem and took it apart. Before the repair there was no "click" when I pushed the button, a clue to the problem. The on-off button on the front pushes a weakly made angle piece of plastic inside which had broken. The plastic piece in turn is supposed to push an internal switch which is offset to one side.
I used epoxy (Araldite) to repair the broken plastic angle piece, but it still looks weak to me so I switch the tv off at the wall and leave the on-off button alone (though it does work now).
Opening the case requires some knowledge and care, and can be dangerous. It may void the warranty so be careful or give it to a qualified repair person.
Hope this helps!
Posted on Jan 09, 2009
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
Went to turn on tv and nothing happened. not even the red light powered up. it worked just fine the night before and nothing is out of the norm. got any ideas? I've got power to the power strip. would the...
Tries unplug,replug an hour later.Still no power than.Ur power board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | Zenith Z50P3 50 in. Plasma TV
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Tv wont turn on
Hope this helps!
Dec 12, 2007 | Televison & Video
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Tv wont turn on
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 14, 2007 | Toshiba 55H70 55" Rear Projection...
Panasonic CT-32SC13 32" TV Logo
490 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
