Question about Lexmark Office Equipment & Supplies
Lexmark x7550 document feeder not taking pages of document for fax
    Problem Solver:
  • 15 Answers
Try cleaning the Feeder wheels that feed the paper in. Use a Dry cloth to wipe away paper fibers. They can cause the printer not to be able to grab the paper.
Rj
Posted on Nov 03, 2008
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
I was wondering how to scan more than one page at a time with the x7170. also is there any way to save the scanned document as a microsoft document?
The Lexmark X7170 printer can only scan one page at a time. However, it has the capability of scanning multiple pages using either the scanner glass or through the automatic document feeder. Refer to the Lexmark X7100 Series User's Guide for more information.
For your second question, Yes, you have an option to save your scanned file to a Microsoft document as long as the Lexmark OCR scan software is installed on your computer. The scan software is only available on the installation disc (not available as part of the downloadable driver on the Lexmark website).
May 12, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
How do i fax several docs. to same number/?
Actually, it's just like sending a single-page document to a particular number but you just have to insert the multipage document in the feeder. Here's the Lexmark X4270 User's Guide for your reference: http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html. Go to Sending a Fax in Faxing for instructions on faxing multipage document. However, if you're gonna be having a mechanical problem on the printer, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
Fax
Hi. To send fax on your X4270 printer, place the document in the feeder facing down. For additional information on how to send a fax, here's a link to the Lexmark website where you can download the User's Guide. http://bit.ly/d3t61I . Click on Publications tab on the center of the page. Choose User's Guide (Lexmark X4250, X4270). It will give some instructions, as well, on how to do other functions/features of the printer. Hope this helps.
Mar 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
I reinstalled xp and attempting to install lexmark x7550 everything loads except fax drivers
Suggest uninstalling existing 7550 drivers, rebooting and reinstalling the 7550 drivers.
Sep 23, 2009 | Lexmark X7550 InkJet Printer
How do i fax multi pages at once
Your document feeder should allow you it install a stack of originals, amount depends on machine specifications. Dial one number and send your multi-page document.
if not the feeder tires may need to be cleaned, a few drops of alcohol in the center of a clean piece of paper then run it through the feeder, put the paper in then when it stops press the stop button and it should eject the document, in doing so pass the alcohol past the feed tires. do this a couple of times then try your multi-page document again.
Hope this helps
Ed
May 04, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Jun 19, 2008 | Lexmark X8350 All-In-One InkJet Printer
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
