Question about Whirlpool Washing Machines
Unable to cancel cycle or restart cycle. Time left keeps blinking. Tried to unplug and plug it back in to no avail. Whirlpool Duet HT front loader
    Sergeant:
    Champion:
  • 324 Answers
Sounds like it could be a stuck keypad on the user interface or bad control
Posted on Nov 03, 2008
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
I tried to cancel the cycle. By depressing the correct button. Now the time left is continuously flashing, the door is unlocked though. I can't cancel or restart even when i go to new programs.
Hello, Try to unplug the unit for five minutes. Sometimes it can get stuck just like a computer. I hope this helps.. Please dont forget to rate me:) Thank You..
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a front load whirlpool Duet washer I stopped the wash cycle to put more clothes in now it just flashes the time left in the cycle but will not restart what can I do?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Can't unlock door to Whirlpool Duet HT
remove the lower access panel w/ 3 torx 20 screws and by putting your hand up the rt side approx12 inches or so you'll feel a quarter sized lever attached to bottom of the latch assy, its a manual release for the electronic lock, just give it a tug down it come open at least. the remove the top of the machine and look down on the door lock as well as the computer mounted on back wall looking for loose connections, unplug and replug the wiring connectors
Mar 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
