Question about Canon PowerShot A85 Digital Camera
Review switch Having had no problems since new 18 months ago, my A85 is stuck in review mode leaving me unable to take any pictures. The switch now has no effect. The unit has been very well looked after and not subjected to any shocks or damage. Is this a return to Canon to fix it or would it be economical simply to buy a new one? (not under warranty)
  • Alan Farthing Sep 27, 2006
    Hi Scrajmer,
    Thanks for your input.
    I had suspected as much.
    Is it something that a competent technical person (ie me) could repair and, if so, is it possible for an individual to get the parts from Canon?
    Just been into Jessops and they quote £100 just to get it looked at. A new equivalent camera is only £175.
    QP
  • Alan Farthing Sep 09, 2007
    I thought that I'd have a look inside the camera to see if there was anything obvious. The actual switch is part of the circuit board and thus it's replacement is not cost effective.
    However, I found that the toggle which is part of the case had simply jumped out of alignment with the switch.
    After carefully putting it all back together I have had no further problems.
    Removing the back. however, was VERY tricky. I think I found a site that gave some hints but cannot remember it now.
  • 188 Answers
It seems that the switch to toggle between camera mode and playback is broken, as it happens in most of the cases. the replacement of the switch will do the job.
Posted on Sep 27, 2006
When i turn on my camera the monitor remains black and does not show anything that it is aimed at.If I try to take a picture it will take but shows up black on review. Although when I switch it to review...
It is ccd imager chip failure in your Canon A85 camera and ccd imager chip willbe replace to get live view to take pictures.
Canon offers free of cost repair for A85 model for same problem. Click Canon CCD Imager Advisory for details and check your camera model number in that list.
Thanks.
Oct 02, 2009 | Canon PowerShot A85 Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Our camera when you turn it on has a blank screen and you cannot take pictures. You can review pictures and see the different menu modes, but the screen is otherwise black. We have had it repaired once for...
See this link:http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=9824&keycode=2112&id=48264Your camera is one of those listed, and your symptoms indicate this is the problem. Canon should repair your camera at no cost. Keep trying! You have a valid case.
Jun 16, 2009 | Canon PowerShot S1 IS Digital Camera
I TURN ON MY A70 AND I GET A VIEW OF THE LAST PICTURE I TO TOOK.
The camera is stuck in picture review mode. Try sliding the mode switch back and forth a couple times, and leave it in camera mode to see if this corrects the problem.
Apr 02, 2009 | Canon PowerShot A70 Digital Camera
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
Lens is stuck open
We had the same problem with a Casio Exilim. Had been stuck for months...had nearly given up until I saw another post about banging the camera pretty forcefully to get the lens unstuck. I hit it once on the bottom onto my desk(w/ paper and blotter on the desk-so soft), then twice with the back of the camera against the desk. I turned it on and the lens was unstuck!! Immediately took a couple pictures and it seems to be working fine! If the camera may be lost, you've got nothing to lose to try this out...Good luck!
Apr 26, 2008 | Casio Exilim EX-S500 Digital Camera
How to delete a picture
Slide the upper-right slide switch down to put the camera in picture review mode. Press right or left on the circular switch to find the particular picture you want to delete. Then press the upper left "trashcan" button to delete.
To erase ALL the pictures, leave the camera in picture review mode and press the menu button. The erase command should be around the fourth item listed in the menu that pops up.
When done, don't forget to slide the upper-right switch up to put the camera back in picture taking mode.
Apr 21, 2008 | Canon PowerShot A570 IS Digital Camera
Can't switch from photo taking to photo review
Assuming your LCD still works, go to the camera settings and reset the entire camera to the default factory settings. This will help you determine if it is a hardware or software problem. If you are still unable to get into the photo review, you may have a hardware problem.
Dec 24, 2007 | Canon PowerShot SD1000 Digital Camera
I can review, but not take pictures or video
Well, I have the same problem. Looks like the mighty SONY has created a turd and now I need to spend another 300 plus dollars for another one. Thanks Sony!
Oct 13, 2007 | Sony Cyber-Shot DSC-S90 Digital Camera
S5000 - camera does not display images in 'review' mode - still stays in photo shoot mode
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Dec 24, 2006 | Fuji FinePix S5000 Digital Camera
Canon PowerShot A85 Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
