Question about Bowflex Treadclimber TC5300
Bowflex treadclimber 5000
My machine makes a loud squealing noise, like something needs to be greased on the treads. Is there a service person who does maintenance on these machines?
  • Anonymous Mar 20, 2014
    I use it regularly and noticed and oil spot on the floor/pad under one of the cylinders?
  • 41 Answers
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Posted on Nov 03, 2008
I tired to recalibrate my bowflex tc5000 and it says the cablibration failed. The belts dont seem to want to turn at a high enough speed.
Posted on Dec 07, 2008
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
Start shuts down machine and blows circuit breaker
see the video attached. and proceed according. However you must test the power cord for short circuit. some wires is touching each to another. Or the outlet wall the wires are loosing touching each to other and blowing the c.breaker, or call some electrician for to fix it.
God bless you
Oct 17, 2013 | Bowflex Tc5000 Climber Treadclimber...
How to lubricate tc500
Nice machine! I use WD 40 on my machine. It comes with a small tube attached to the can that lets you get into joints and bearings easily. Keep the can handy if you work out regularly..it keeps it quiet and smooth!
Jan 12, 2013 | Bowflex Tc5000 Climber Treadclimber...
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My machine is making a grinding sound (medal to medal) when i use the machine. if i lock it and only use treadmilll it is ok. it seams to happen more and more. i really grinds if i stand on step offs....
You'll need inspect the movable areas of your unit by hand something may have come loose or see if their is any excessive lateral play could be worn or cracked bushings. Have some else help you by stepping off on either side to see where the sound more prominent. Unfortunately it a process of elimination good luck!
May 29, 2010 | Bowflex Treadclimber
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Sensor wires detatched during initial assembly of Bowflex TC1000
You will need to make contact with bowflex if you broke the item. You may be able to glue back the item as well. The front lid come off, sometime you have to tilt the machine with another person. This will allow you to get to the under side.
Jan 28, 2009 | Bowflex TC3000 Treadclimber
Bowflex Treadclimber TC5300 Logo
1,196 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
