Question about Brother MFC 210C All-In-One InkJet Printer
Printer continuously cycles power.
I picked up this non-working printer at a garage sale. The printer powers up normally, goes through its initialization cycle all the way to the idle screen ready to print/copy. Then about 70 seconds later, the printer goes through the power up cycle again as if it was unplugged. This repeats forever. In copy mode I have managed to print about half a page until the power up cycle repeats. I haven't connected the printer to a PC yet. I've taken the printer apart to inspect the power supply and controller boards. Nothing visibly wrong other than a few suspect solder joints which I touched up. The main controller IC seems to run a just little warm, but still touchable. Put the printer back together, but the problem remains...
  • Tony Quiroz Oct 07, 2006
    I went to Brother's and checked for technical support for this printer. I found a firmware upgrade. Loaded the upgrade to the printer per the site's instructions. The printer works fine now.
Hey, i need your help.i bought a Brother MFC-210C, i was experiencing a power cycle problem so i decided to do a firmware update. Durning the update everything was going fine until i got an error stating that the "Stop botton was pushed" and the communication link was broken. I did not pushed the stop botton but it said that it was which was strange. But on the printer lcd, it showed that the update in pregress even though the firmware tool was closed on my system. After leaving the printer that way for about 15minutes i decided to unplug the printer due to the fact that the power key nor any other was responding. When i turn the printer back on i got a ring and there are only blocks on the printer lcd along with the 4 lights for the copier, scanner, memory cards etc on. When i attempted to reconnect the printer, i'm unable to install the drivers and i'm bring prompt for drivers for a "USB device" another "USB Device" and a "BrotherBHL2-Maintenance" driver. I'm lost and don't know what to do. i've tried several web searches and without any success in solving this problem. I need to use my printer for school so is there anyway in which this can be fixed? I'll accept any help. thanks
Posted on Oct 24, 2006
The printer continues in Self Test, the printer is stuck at this point as it tries to continue to cycle through the power up.
Try to power on the printer without the toner kit and the waste toner box. If the printer stacks again at self test. Next step.... remove one part at time and check if the printer displays any message. First remove the developer unit and power on the machine (normal message "Missing Developer Unit"). Then pull out the fuser unit and power on the machine (normal message "Close Rear Cover"). And finally, remove the Drum Unit and power on the printer (normal message "Call Service 7410").
If the printer still stacks at Self Test, then that is not a good sign. Try to upgrade the printer' s firmware (system + engine). There is a possibility to go further from Self Test.
If it does not, then you have to replace the main pwb.
Oct 28, 2014 | Kyocera Fs-3920dn Laser Printer
Lasterjet m1212 nf MFP printer refused to print, it keeps initializating, how to solve it?
connect the printer directly to the walloutlet....
try with a different walloutlet as well....
then unplug the power chord from the back of the printer as well as other cables if it is connected without turning the printer off...
then press and hold the power Power cycle unit by switching the power switch off, wait for 10 seconds, then power on..
if it does not work then
  1. Turn the printer off.
  2. Press and hold down CANCEL and Start Copy buttons at the same time while powering on printer.
  3. Continue to hold down buttons until the control panel display reads PERMANENT STORAGE INIT.
  4. Release the buttons. Printer will return to Ready automatically
Hope this helps
Oct 29, 2012 | HEWLETT-PACKARD M1212nf All-In-One Laser...
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Hp M2727 goes into low power sleep mode and can only recover by cycling power
This is a problem with the formatter board, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years. Al
Jun 30, 2010 | HP Laserjet M2727nf Multifunction Printer
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
My dell printer wont turn back
Power down the computer and the printer. Disconnect the printer cable from the computer. Disconnect the power cable on the printer for 30 seconds or so. Without connecting the printer back up to the computer, turn the computer back on as you normally would. It may come back to the screen that asks you if you want to start windows normally or in safe mode. Start windows normally if you do not know how it got to that point. Once windows is started then go back and go through your shutdown procedure and let the computer power down completely. Now reconnect the power to the printer, but not the cable to the computer. The printer should come back on. If it does not come back on standing alone not hooked to your computer then you have a power problem. If it does come back on (powers up). Then turn it back off and reconnect your printer cable back to the computer. Turn the printer back on first, then power your computer back on like before and let it cycle on until you get to your desktop. By this point everything should be on. Let me know how it goes ,but I believe by going through the cycling on and off of both units you'll get back to normal operation. From your posted problem this is the best solution I can give you. God bless.
Jan 21, 2009 | Dell A940 All-In-One InkJet Printer
Printer unable to obtain IP address
Reset the TCP/IP information. To do so, Turn off the printer power. With the cartridge door open, hold down both cancel and continue buttons and power the printer on. Hold the buttons until the lights cycle. The TCP/IP information should be cleared. Wait a few minutes.The printer should pick up a new IP address from the network, or should set a default IP. Press the Continue button to print a new test page, and you should see the new address.
Mar 24, 2008 | Dell 1710n Laser Printer
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Brother MFC 210C All-In-One InkJet Printer Logo
240 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
