Question about Epson Office Equipment & Supplies
When I print my pictures are coming out cartoon-like.
I just bought new paper and ink but my pictures are not looking as they should. Like I said, kind of cartoon-like with added shadows and if you look closely there are light fuzzy white lines going through them too. I have tried cleaning the head several times.
  • Brandy_0119 Nov 05, 2008
    thank you for your help. It didn't help my problem though. I don't know what res it's printing at, I don't know how to tell?
  • Brandy_0119 Nov 06, 2008
    It's an Epson Stylus Photo RX500 printer.
    Problem Solver:
  • 15 Answers
Try and clean the Gold Contacts on the printer and the print cartridges, Also what Res are you printing them at? You can check that from Prefrences
Posted on Nov 03, 2008
  • R J
    R J Nov 06, 2008
    I'm afraid it may not be the print head that is causing this? It maybe a Circuit board inside! Not what you may have wanted to hear!
    What Type of printer is this and maybe I can find out a little more?
Ive just bought this printer from currys & im trying to print a picture from my memory sd card & the picture is coming out all smudged? could it be because im not using photographic paper?
You should be able to select the paper type you use before starting the print. The printer should optimise the print to match the paper you have specified. If the paper is not for photos, it shouldn't matter too much unless the ink is taking too long to dry. It is more likely that your print heads are skimming the paper or something is brushing the image while the ink is still wet.
Apr 13, 2016 | Office Equipment & Supplies
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Sep 30, 2007 | Canon Selphy DS700 InkJet Photo Printer
Why do my pictures have lines across them?
Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Canon PIXMA Office Equipment & Supplies
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
My color print outs, like mapquest, look like cartoons instead of pictures. I did a noozle check and yellow isn't printing. I took the cartride out and touched a paper towel to it, and the ink came out....
Never use aftermarket cartridges with your Canon Pixma ip5200 inkjet photo printer.
If your cartridge leaks fluid when out, then that's not a good sign.
Try to return for a refund if you just got it.
Aug 19, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
While waiting for more info from you, Look for these :
If you have bought a new cartridge:
Make sure you purchased the right ink.
Make sure you removed the tape covering the print head.
Make sure you have installed the the cartridge correctly.
Look for the expiration date, old cartridges dry out!
If you have had the cartridge in the printer for a long time the ink might have crusted on the print head take out the cartridge and rinse the print head under warm tap water for a minute or so. then dry the hole cartridge thoroughly with a paper cloth OBS! don't rub the print head too much! put the cartridge back in the printer. If it doesn't help, maybe it is time to get a new cartridge!
Happy fixing things!
PLZ, Don't forget to rate!
Feb 01, 2010 | Office Equipment & Supplies
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Jun 22, 2009 | Dell 924 All-in-One InkJet Printer
Printing pictures
If your normal print looks OK, make sure that you are printing your pictures on the correct side of the photo paper. Most photo paper will only print properly on one side. If you print on the other side, the image looks very grainy and faded, and the ink will still be quite wet when it comes out of the printer.
Jun 12, 2008 | Canon PIXMA MP470 All-in-One Printer
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
