Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
KP46WT520 the stand by light flashes for 9 times then it makes a little pause and then it continues doing the same, please help meeeeeeee
  • farmmax May 11, 2010
    I have the Sony KP-46WT510 model. sounds like a convergence problem. what's the link for the parts/steps to fix? thanks, Dave
This is exactly what's happening with my TV. I'm oblivious to Diodes or where the G Board is on the device. Is this something, a normal Joe like myself can fix? Do you know the approximate cost for parts, and labor? I have a service that wants to charge me $100 just to come out and take a look to access the problem..That sounded a little too much for just and accessment.
THX
Posted on Nov 21, 2008
  • Sony Master
  • 8,617 Answers
Thats a zero cross error which usually means either one of both of the two following diodes are open on the G board D6116, or D6301
Posted on Nov 03, 2008
Power light flashes
Hi Sir,
did you solve with your trouble?
perhaps the trouble is on the mainboard,
Dec 12, 2011 | Optoma EX532 DLP Projector
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Sony Wega kp46wt520 no power up, 9 times it blinks red
You will need to replace the G board. You can try replacing the two diodes that usually fail, But because its a complex circuit with the zero cross detection the diode replacement never fixes the issue. Replacing or remanufacturing the G board is the only sure way to fix that issue.
Nov 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
How TV's stand by button is flashing 9 times, what
Sounds like one of these Codes for television repair.
Check out the link above, it may be a bulb needed for your DLP television.
Sep 10, 2009 | Sony KP-51WS520 51" Rear Projection...
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Please help me
Bad Flyback Transfomer replace it.
Nov 04, 2008 | Sony KP-46WT520 46" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
