Question about Cameras
Says no memory card when card is in - Cameras
  • 477 Answers
The problem is you have a bent pin in the memory slot some times you can straiting the pin and it can work fine after that. but some times the main board has to be replaced. hope this helps.
Posted on Nov 03, 2008
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
Apr 15, 2011 | Nokia 6630 Cellular Phone
Memory card corrupted
Try reformatting it by inserting into a card reader connected to PC. If it is indeed only a bad sector in the card then you will lose data but still salvage your card. Otherwise you will lose both card and data. Also, if you are using a linux OS then there are data retrieval methods available from corrupt cards as well. Kindly clarify OS.
Jan 27, 2011 | Computers & Internet
I was using black berry then i switched to nokia e50 and i remove the mmc from black berry and when i inserted it to nokia e50 memory card is currupted how to solve this problem
You may need to format the memory card with your Nokia device.
However, all data in the memory card is permanently deleted if you format the memory card.
It is recommended to back up device memory regularly to the memory card. The information can be restored to your device
To back up information from device memory to a memory card, select Menu > Tools > Memory card > Options > Backup
phone mem.
To restore information from the memory card to the device memory, select Menu > Tools > Memory card >
Options > Restore from card.
Do not remove a memory card when the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
If you cannot use a memory card in your device, you may have the wrong type of memory card, the card may not be formatted
for your device, or the card has a corrupted file system.
Tip: You can install and remove a memory card without removing the battery or powering off the device.
Dec 21, 2010 | Nokia E50
Unlock the password
my memory card need a password and i forget our password
who to unlocked my memory card
Dec 02, 2010 | SanDisk 2GB microSD Memory Card
I put memory card into a card reader and it got stuck and now memory card doesnt work
1. You have removed the memory card forcefully from the card reader, that's why it not working!
2. Does the card reader detects your memory card (even if it's not working)?
3. Check your memory card with a digital camera / card adapter!
please rate this advice if it! :)
Jan 13, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory card isshowing corrupt
That means that memory card is faulty and you must replace the memory card.
Test the memory card on a computer using a card reader and test a different card inside the phone.
If the phone returns same error with all memory cards, then the phone memory card slot is faulty, otherwise just replace memory card.
Jul 11, 2009 | Nokia N70 Cellular Phone
Memory card not support.
Possible reasons:
1. Memory card not formatted.
2. Memory card could be larger than 2GB.
3. Brand of the memory card.
Nokia 6085 uses MicroSD (TransFlash) and it could support up to 2GB. If you're using a memory card that is not formatted or bigger than 2GB, you might get this error "memory card not supported'.
Sometimes, brands does matter. Nokia phones prefer to use Nokia memory cards. So you need to try using different memory card to see if there's a problem with the card or with the card slot on the phone.
Hope I answer your question properly.
Have a great day!
May 30, 2009 | Nokia 6085 Cellular Phone
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Cameras Logo
93 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
