Question about Kenmore Dryers
Kenmore dryer dryer is causing brown marks on my white clothes
    Genius:
  • 1,028 Answers
Ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Posted on Nov 03, 2008
3 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Posted on Jun 18, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Posted on Nov 25, 2008
Brown streaks and stains on white towels
check the drum on both ends to see if the felt wore down or ripped,when this happens your clothes can get into the space and causes the marks on your clothes,also check to see if anything is on the drum,door or back wall,anywhere that the clothes can touch as they spin in the dryer but most likely there's a worn out felt on the drum and clothes are slipping though the space
Feb 01, 2014 | Kenmore Dryers
Clothes, fabrics are coming out of dryer with burn marks
If those marks are little brown marks/they do look like burn marks but your cloths are being pinched by the front and rear felts on the drum//to test that take a white rag reach in to dryer at the edge of the drum front and rear rub the rag// you may have to push it between the drum and the dryer housing you will get brown marks that is rust///If you replace front and rear drum glides (seals) that will cure the problem I would price parts first as sometimes replacement is a lot cheaper.......Hope this helped....If I did please vote If you need more help please ask...Good luck
Feb 05, 2011 | Kenmore Dryers
Brown marks left on clothing.
You probably have significant lint buildup inside the machine. The lint gets burned by the heater and causes the dark marks on the clothes.
This could indicate a fire hazard!!
The solution is to disassemble the machine and remove all lint residue inside, especially in the heater area.
Apr 19, 2010 | Kenmore 62602 Electric Dryer
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Brown marks on the clothes
Yes, the felts are what seals the unit and allows the drum to turn without much heat loss. The felt can become damaged and the clothes will get caught between the drum and the housing leaving these marks.
Apr 09, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer leaves brown spots on clothing articles. Suspect back seals as gaps are evident and drum is loose within the unit. What is remedy? Cost of seal replacement?? Kenmore 62802 Electric Dryer Deb in Brown...
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Mar 23, 2009 | Kenmore Dryers
White clothes come out of dryer with brown lines.
Run a rag along the inside drum seals to see if this is the source of the brown lines. Replace the front and rear drum seals. Part number is 280114.
Mar 06, 2009 | Kenmore 63942 Dryer
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
449 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
