Question about Texas Instruments TI-89 Calculator
"Too Few Arguments" Error
When ever I try doing limits or differentiate the error code comes you "too few arguments". Any suggestions on what i am doing wrong???
  • 49 Answers
The problem is you haven't given it anything to solve...
always add a comma and the variable after any solve, differentiate or intergrate problem...
eg:
solve(x^2=4) is wrong!
intead put:
solve(x^2=4, x)
Hope this helps
Posted on Nov 06, 2008
  • 2 more comments
  • Shepherd455 Aug 18, 2011
    thanks, i was having the same problem and this solved it.
  • YESSY Dec 05, 2011
    Hey...this helped! I tried looking in my manual, but didn't find a thing....THANK YOU!
    Hey this helped...I tried looking in my manual, but couldn't find a thing! THANK YOU!
  • William Smith
    William Smith Oct 28, 2013
    But I do enter the comma, variable and final parenthesis and I still get the "too few arguments" error. I'm about ready to flush the calculator down the toilet!
I have a schumacher xp2260 and am getting an error code of r02 but cannot find any information about it. Please tell me what it means and how to fix it.
I have no information on this fault. I suggest you contact the manufacturer directly with the question, but really doubt it will be something you can fix yourself.
Jan 09, 2017 | Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
Toshiba e-Studio 456 Error Codes F901
The challenge is with the speed of LGC is not corresponding to the model of the machine installed now try to check it if theres no harness for connecting to the connectors of LGC Board of CN311 and CN316
Jan 09, 2017 | Toshiba Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Can i print Recipes & Instructions book
Yes you can! Here are a few sites for recipes. Kraftfoods.com, cookiefest.com, foodtv.com cookiesetc.com bonniescookies.com, ETC, If you want more recipe sites. Just type in on pc, what your looking for. Crafts, recipes, or what ever. My wife uses the recipes a lot. If you do not know how to make a certain thing, just type in search bar on pc. Hope this helps! Good-Day!
Aug 29, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Texas Instruments TI-89 Calculator Logo
9,442 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
