Back to:
Tags:
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
The water and ice dispenser is not working (by 6 users)
posted by vikki on Sep 27, 2006
The water and ice dispenser is not working, the light goes on and off to normal and dim. There is a low tone bonging sound.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Aug 26, 2008
not making ice
Comment by bearlady1, posted on Jun 24, 2008
ice and water do not dispense ice is being made
Comment by bairo, posted on May 27, 2008
the ice maker is working propely , however the water is not. I checked the lines and water is present with enough pressure but water will not come out through the dispenser.
Comment by Guest, posted on Mar 15, 2008
I HAVE THE SAME PROBLEM EXCEPT MY ICE MAKER WORKS AND NOT MY WATER
Comment by firemike, posted on Nov 22, 2007
Sounds Like the same problem. In my case the light comes on dim, if you wait a few seconds the light will get brighter and then it will dispense water, but never dispenses ice. The ice maker continues to produde ice just fine, it just won't dispense ice at the door.....
Best Solution
posted on Nov 09, 2006
Thanks for Trying (70)
HVACRH20
Rank:Guru Guru
Rating: 85%, 1244 votes
Start with the easy stuff. Is there water at the refer? Remove the line from the back and check for water flow. If equipped, is the filter plugged (water flows without filter in sort of thing)? Is there debris in the line to the refer blocking the valve? Does the water valve solenoid "click" and flow water if you remove the internal water line that goes to the frige interior? Is the water line frozen in the door (turn off frige for a day and check water flow).
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on The water and ice dispenser is not working:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
lg electrocool fridge is leaking
Refrigerators
wiring diagram freezer affc1526dw1
Refrigerators
we have a new frigidaire freezer and the setting is locked...
GE GSH25JSRSS Stainless Steel Side by Side...
I just got my frigidaire and when the movers came to drop...
ice maker keeps giving me crushed ice even when i don't...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
