Question about Gateway SL9550-30165318 Notebook
Laptop screen illumination
I just recently installed a new screen for my laptop when everything was installed i turned it on to make sure that i had properly connected everything the screen worked for a few seconds then went completely dark i can see the image on the screen but like i said it is completely dark any help would be appreciated
  • Gateway Master
  • 32,281 Answers
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 24, 2009
Sony vaio pcg 4a1l blank screen after replacing a new screen
Take it apart again, remove housings, disconnect cables, reconnect cables, and then power on. If that works then re-assemble
Oct 18, 2013 | Sony VAIO Computers & Internet
My Philips X58 Freevents laptop's screen has stopped lighting up, however I can just see that there are my programmes on the screen if I shine a torch onto it. Can you advise the fault and how best...
A faint and barely visible image on the screen indicates that the backlight(s) that illuminates the display isn't powering on. A device called an inverter board takes DC power from the laptop motherboard and converts it to AC power to power the screen backlight.
Before attempting anything below, be sure and remove the laptop battery and unplug the laptop
You need to take the screen apart and check to make sure that no cables are loose that are connected to the inverter board. If everything is secure, the next thing I would do is try to test the inverter board by hooking up an LCD from another laptop to the inverter and turning the laptop on to see if it lights up. If the other screen does light up, then the inverter board is likely good and your backlight needs to be replaced. Backlight replacement, unfortunately, can be very tricky for even an experienced technician, and many will opt to just replace the entire screen.
If you can't test the inverter board, then it might be worth it to order one and see if installing it fixes the problem.
Youtube is a great place to check for instructional videos on laptop repair, such as this one:
http://www.youtube.com/watch?v=jjXLR5yY7X4
Finally, if you can't or don't want to repair the display problem, then you can always hook an external monitor or a television up to the video port and use your laptop that way.
Sep 24, 2011 | Computers & Internet
My Sony VAIO Laptop screen is black. It worked fine, no issues2 days ago. Went to turn it on last night and it is black.. When light hits at a certain angle, I can see the desktop, I can hear the startup...
Sep 21, 2011 | Sony Computers & Internet
Laptop New LCD Screen Cycling Colors
It's probably the wrong screen, cable ,or inverter; in spite of what the repair shop tells you .
Also, sometimes the cable gets pinched if not installed carefully, or the cable connector may need to be re-seated.
Is your laptop a Dell Precision M60 ? I'll see which screen it's supposed to have.
Jul 28, 2009 | Dell Precision M60 Notebook
Hi i have got a medion mim2230 laptop. when i turn it on i get a page that comes up and says 'sorry for the inconvienience, but windows did not start successfully. a recent hardware or software change...
hi
i have had the same fault with my medion mim2230 and tryed everything you list and i now have put it down to a battery pack fault why i say that is i removed my battery and laptop works ok some i ordered a battery of
ebay and placed it in my laptop and now its ok but just to make sure
i put my old battery pack back in my medion mim2230 and it come up with the same fault again so turned laptop off and replaced my laptop battery with my new one from ebay and its working ok
May 14, 2009 | Medion md40298 Notebook
HP dv2799ea....no VGA information presenting, display illuminates.Nothing from Aux VGA.CMOS reset, memory modules checked.System proceeds through PCI listings screen & Past boot to OS (Vista)I suspect the...
try repairing your vista installation with your vista dvd, if you see the laptop boot through bios and everything then your VGA adapter is fine...
Apr 26, 2009 | Computers & Internet
Acer ASpire laptop
sounds like its trying to load windows but the harddrive is failing to respond, most of the time if it loads everything up to the windows itself its all done before initalizing the harddrive itself.. try putting the harddrive into another computer or usb external to check if its dead.. you might just need a new one =T not 100% sure though but its worth trying.
Jul 28, 2008 | Acer Aspire 5100 Notebook
Acer Extensa 2300 LC -
try this without battery installed. see if that does anything..
Feb 21, 2008 | Acer Extensa 503T Notebook
Backlight/screenlight 4 laptop
The printed circuit board in the lower part of the screen is probably the LCD inverter board. If you can see the image on the screen and you?re sure its not just LCD persistence (similar to the old CRT burn in except it can be fixed) then are probably correct that it is likely the cause of your problem. The only way to tell for sure that?s the problem and not the less likely florescent tube failure is to replace it and see what happens.
Apr 13, 2007 | Fujitsu AMILO Pro V1000 Notebook
Gateway SL9550-30165318 Notebook Logo
138 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
