While printing, my printer stop printing in the middle of the job.What's going on?
** Spooler Issue fixed **
I had the same issue before and now I got my problem solved help of this follwoing article please click below and follow there mentioned steps and get your problem
fixed.
Click here to open solved Solution for this problem Spooler not working (Solved)
http://www.techsupportall.com/print-spooler-is-not-running/
It could be the Print Spooler service on your computer that's not properly working. Try these steps to fix the problem: Try to
print a document again to verify that the problem is fixed.
SOURCE: lexmark x1240 printer will not print.
Keep your paper feed under 15 pages. The paper will tend to pull to the right, but it will print correctly on the printed page. 20 to 25 pages in the feeder will result in a paper jam. To find the status on the print job, go to your control conter and hit printers. Choose your spicific printer and you may beable to save the printjob.
SOURCE: printer locks up
If you are having difficulty deleting the print jobs in the printer spooler, do the following:
SOURCE: Lexmark 2380 plus won't stop printing
i think its a firmware issue for me..
I experience it before with my printer ..
I just flash with another firmware..
and if the problem still exist..try to
uninstall printer driver and install another one.^_^
SOURCE: printer won't delete job
First goto Start>run>type services.msc then find print spooler then stop it ...
Goto Start>run>type spool > goto printer and delete all files ...
at last goto Start>run>type services.msc then find print spooler then start it ...
SOURCE: Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
