Question about Philips 32PT6441/37 32" TV
My Tv just keeps turning on and off with no pattern
Our Tv just started to turn itself on and off constantly. We tried unplugging it and plugging it directly into the wall.....didn't help.
    Sergeant:
  • 337 Answers
The first and most obvious thing to check is if the power button has been push in too far in,other than that the unit is going to need service,if you are familiar with tv service you can try removing the back cover and pulling the chassis back a little to make sure the buttons are not making contact with the momentary switches inside the unit.Make sure the unit is not plug in while you do this.Be careful or be safe and call for help.
Posted on Sep 27, 2006
Turning off and on loud noise
Check and replace damaged component/s at its 'Mute' circuit. Contact any service technician. Gopakumar Gopalan Google
Apr 01, 2014 | Televison & Video
Tv keeps turning off after turning it on.
Based on the lower specification of this TV any repair is more than likely going to exceed the cost to replace it, One of the internal components has failed and generally unless you are handy with an oscilloscope it's not worth fixing.
May 04, 2017 | LG Electronics - 32LS3400 - 32 Led 720p...
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
Tv keeps switching on and off and will not stop
unplug tv for 2 minutes and plug it back in. problem should go away. if not, call toshiba.
Jul 22, 2009 | Toshiba 27AF41 27" TV
TV turns on by it self then constantly changes channel
the controler brain has to be replaced main bord
Feb 03, 2008 | Televison & Video
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
Tv will not turn on but it constantly blinks and will not stop
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Tv keeps turning itself off
you must contact service bycouse you need the asistance
May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Philips 32PT6441/37 32" TV Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
